Problems updating KDE Plasma Mobile OS
I'm experiencing problems updating my OS (KDE Plasma Mobile).
I'm using a SD Verbatim 32 GB (just KDE Plasma Mobile on it).
On the terminal, after:
$ sudo pacman -Suuyyw
got this message:
error: failed to update mobile (unable to lock database)
error: failed to update core (unable to lock database)
error: failed to update extra (unable to lock database)
error: failed to update community (unable to lock database)
error: failed to synchronize all databases
Also, tapping on Discover, on the bottom of the screen, when the application starts, I got:
Any help?
Many thanks.
Something set a lock on your package database.
Try:
sudo rm /var/lib/pacman/db.lck
Then try your update again.
Followed the above instruction and then started  pacman -Syu. After a lot of screen activity I was asked to approve an update. The keyboard was locked and I could not respond. I shut down. I now have an OS that will not boot. Should I take a hammer to my phone? Perhaps I should download Manjaro and burn it to a micro SD instead. From where should I download the most recent (and hopefully functioning) version? Thanks in advance.
Download a current stable version of your favorite distribution ( A good list of distros is available here: https://wiki.pine64.org/wiki/PinePhone_S...e_Releases ), and burn the image to an uSD card. Try them out for a while and when you find the "one" install it to the eMMC utilizing jump-drive.
If you want to stick with Manjaro Plasma Mobile, here is a link to the current stable release: https://github.com/manjaro-pinephone/pla...beta15-rc3
If you run into trouble, post here or in one of the chat platforms listed here: https://www.pine64.org/gettings-started/
@ionmich
I just notice your post about openSUSE https://forum.pine64.org/showthread.php?tid=18417 . - I am an openSUSE enthusiast, but there isn't anyone working to get it running smooth on the Pinephone.
If you want a good stable cell phone experience, I recommend you stick with Phosh on Arch, Mobian, or PostmarketOS. - I currently daily drive my Pinephone on PostmarketOS Phosh stable. - It just works.
Install something stable on the eMMC, and then play with other distros and desktop environments on uSD cards.
Thanks for the advice. I ran into ignorance problems on Arch so I will try the next two.
(06-30-2023, 10:54 AM)ionmich Wrote: Thanks for the advice. I ran into ignorance problems on Arch so I will try the next two.
Just an F.Y.I. Mobian requires tow-boot, so maybe PostmarketOS first.
Here's a link to the Mobian wiki outlining how to install. https://wiki.mobian-project.org/doku.php...tall-linux
I ran into trouble with Mobian and gave Arch another attempt...with success, and so far it's doing what I want. Thank you!
  can I retrieve accidentally deleted voice mail with T mobile ? HLing 4 640 12-13-2023, 01:24 AM
Last Post: oldschool
  New Zealand network providers mobile data Linux2thabone 3 3,178 08-05-2023, 06:17 AM
Last Post: SchizoPinePhone225
  US Mobile, via T-Mobile, won't support Pinephone Pro - SOLVED, SIMPLY jovval 10 2,977 07-07-2023, 12:06 PM
Last Post: jovval
  Udating the firm,ware? Potential problems? KNERD 2 821 06-12-2023, 07:56 PM
Last Post: KNERD
  Current Situation With Setup and Carrier Activation With Tracfone Verizon T-Mobile pinephoneuser22 0 644 05-26-2023, 08:40 PM
Last Post: pinephoneuser22
  Cannot call at several mobile phones Gon 3 1,231 05-04-2023, 05:18 AM
Last Post: Gon
Lightbulb pinephone mobile dock jasmin763 2 1,635 06-06-2022, 09:06 AM
Last Post: 98cwitr
Question Mobile data suddenly gone epiii2 1 1,282 05-23-2022, 04:57 PM
Last Post: epiii2
  plasma-dialer doesn't call Ant 7 3,812 04-08-2022, 03:09 PM
Last Post: israel
  Mobile case wanted - with wireless charging! thorensjubilee 4 2,778 03-19-2022, 10:29 AM
Last Post: vap0rtranz
