MMS sending stopped working
I've been mostly-happily using the PinePhone with Mobian for a long while (years), with MMS working pretty smoothly for a long time. Recently (last 5 days or so), MMS sending has completely stopped working.
  - It didn't happen after making any big software change (apt upgrade, settings change, things like that).
  - Group message sending and 1-on-1 media sending no longer works
  - Group and media receiving still works totally fine
  - Back when MMS sending was working, I noticed that after hitting "send" on an MMS message, the screen brightness would always change for a moment (something to do with power draw to the antenna?). Now when I try to send MMS that doesn't happen.
Any idea what the problem could be?
(01-13-2023, 04:00 PM)amindfv Wrote: I've been mostly-happily using the PinePhone with Mobian for a long while (years), with MMS working pretty smoothly for a long time. Recently (last 5 days or so), MMS sending has completely stopped working.
If it did work before most likely your carrier change something. I am quite sure that because of some carrier changes kop316 need to do some changes (not affecting to me so can't confirm and this comes from my memory so might be wrong).
What you can do is try to upgrade and see what happens?
MMS is complicated and the biggest problem is almost always your carrier (not your own OS or mmsd-tng)
Best place for mms questions is matrix room
#opensourcemms:matrix,org
There was a recent update to mmsd-tng (v2.1.0) to fix a problem that came up with T-Mobile.
  4G VoLTE calls confirmed working with carrier x dcinoz 15 11,873 03-09-2024, 11:38 PM
Last Post: dcinoz
  SMS not delivered if receiver offline at sending time alpineduck 14 3,733 09-04-2023, 10:38 PM
  Instructions to get pinephone working on USA carrier omarcomputing 1 1,371 10-08-2022, 04:45 PM
Last Post: treebeard
  stopped receiving text messages jyoung 11 6,128 07-29-2022, 05:36 PM
Last Post: jyoung
  JumpDrive isn't working phytocube 2 1,789 06-05-2022, 03:22 PM
Last Post: phytocube
  SIM card slot not working dekrets 2 2,216 02-12-2022, 11:09 AM
Last Post: dekrets
  Can't get autofocus working duncan_bayne 4 2,950 01-22-2022, 09:17 PM
Last Post: duncan_bayne
  PinePhone Beta 3GB modem not working hannescam 15 9,121 01-19-2022, 02:08 AM
Last Post: bcnaz
  Video Out not working BenniTec 7 5,187 10-21-2021, 11:56 AM
Last Post: BenniTec
  How did you get data working on PureTalk? nelstomlinson 2 2,902 09-26-2021, 03:50 PM
Last Post: nelstomlinson
