How did you get data working on PureTalk?
I have a PureTalk sim in the phone. It gets calls and texts, but data doesn't work. I keep getting texts warning me that the 3G is going away; I suspect that is connected to no data.
Settings shows, under Modem Details:
Carrier PureTalk
Network type LTE
Signal strength 44%
Network Status Registered
Under access points:
Access point name att.mvno
Running Mobian Bookworm on the eMMC.
Any ideas on how to get data working?
Pinephone beta edition, convergence model, Mobian Bookworm with Phosh.
(09-25-2021, 10:21 AM)nelstomlinson Wrote: I have a PureTalk sim in the phone. It gets calls and texts, but data doesn't work. I keep getting texts warning me that the 3G is going away; I suspect that is connected to no data.
Carrier PureTalk
Network type LTE
Signal strength 44%
That is a common mistake when "Setting Up"
It should be   Name : Pure Talk  and
 APN : RESELLER
and if you want to use the 'Hot Spot'
You simply call support and ask for the  Hot Spot option to be 'turned on'
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(09-25-2021, 12:02 PM)bcnaz Wrote: ****
 APN : RESELLER
APN RESELLER worked.
Now the Pure Talk SIM is in my old Blackberry, since the speaker died and I can't use it any more, but that worked in the Blackberry, and would probably work in the PP.
Now I have to call GCI and figure out how to get data working on their network, since I'll be using the PP as my daily driver, ready or not.
  4G VoLTE calls confirmed working with carrier x dcinoz 15 11,797 03-09-2024, 11:38 PM
Last Post: dcinoz
  how to backup user data? Uturn 1 670 08-30-2023, 05:23 AM
  New Zealand network providers mobile data Linux2thabone 3 3,279 08-05-2023, 06:17 AM
Last Post: SchizoPinePhone225
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 4,232 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
  PureTalk work with Pinephone? car46999 6 2,867 01-30-2023, 12:05 AM
Last Post: car46999
  MMS sending stopped working amindfv 2 1,232 01-16-2023, 09:44 PM
Last Post: treebeard
  cell data and MMS on AT+T prepaid ossands 2 1,448 10-13-2022, 07:28 AM
Last Post: ossands
  Instructions to get pinephone working on USA carrier omarcomputing 1 1,357 10-08-2022, 04:45 PM
  JumpDrive isn't working phytocube 2 1,777 06-05-2022, 03:22 PM
Last Post: phytocube
Question Mobile data suddenly gone epiii2 1 1,338 05-23-2022, 04:57 PM
Last Post: epiii2
