looking for pandoc binary for pinebook pro
I installed manjaro on my PBP, and am very happy with it. But I really need pandoc in order to make it my daily driver, and manjaro does not have pandoc in their repos for arm64. So I thought I would ask people running different distros to check and see if pandoc is available from their respective repos and indicate yes or no in a reply? Any help or suggestions are much appreciated, and I would add that pandoc on my pinephone would be awesome too.
Thanks.
According to their site (https://pandoc.org/installing.html#linux) it's unlikely you'll find it. It appears they only offer support for x86 platforms.
(08-25-2020, 07:15 AM)tophneal Wrote: According to their site (https://pandoc.org/installing.html#linux) it's unlikely you'll find it. It appears they only offer support for x86 platforms.
This link https://www.reddit.com/r/linuxquestions/...andoc_arm/ suggests it is available from the standard repos in the debian distro. I will try that and report back here.
(08-25-2020, 07:22 AM)codebreaker Wrote: This link https://www.reddit.com/r/linuxquestions/...andoc_arm/ suggests it is available from the standard repos in the debian distro. I will try that and report back here.
Just stumbled upon this issue: https://github.com/jgm/pandoc/issues/5450 and it looks like some have started provided aarch64 binaries. I was wrong, my bad.
So I created pkgbuild files to package pandoc and pandoc-citeproc for Manjaro (Arch) on the pinebook pro. The repository is here:
https://github.com/cbrown1/pandoc-arm64
Awesome, glad you were able to make it happen! You should submit your pkgbuild to the AUR, too!
Thank you so much, this was a real problem on PBPs ! I second tophneal : that would be even more convenient for everyone if the pkgbuild was on the AUR.
  Debian on Pinebook Pro u974615 7 1,010 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,582 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,143 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,220 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 88,802 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,232 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,261 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,480 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,585 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 660 07-13-2023, 05:21 PM
Last Post: owaspfap
