Not booting after latest update
I issued an
apt update && apt upgrade
a few hours ago and since then it's not booting anymore. I just see the LED shining in white. The screen remains black.
I saw that it was installing the 5.7 kernel, so I guess it messed up u-boot.
I had it installed to EMMC, so I hope I will be able to restore everything by booting from SD. Can I just reinstall u-boot? What are the commands to do so?
I'm also still on the old version where /boot was on the root partition. Maybe it is also because of that. I guess, when I'm already in the process of repairing I could also repartition.
(06-25-2020, 03:13 PM)Boern Wrote: Hi,
I issued an
ditto! Also on old single partition version. Have backed up my user directory and figure I will start from a new 2 partition download.
1 thing I have noticed - on my trial Mobian/jwm version the screen is flashing like a disco light after the 5.7 upgrade, virtually unusable. Hope the Mobian/phosh version is OK.
OK, installed 20200625 nightly and it seemed OK. Did the upgrade to 5.7 and after reboot have dark screen - can't find a way to get it legible.
Suspect for now avoid 5.7 kernel?
Yep, should have checked here first Tongue
Have been updating daily for the last few weeks without too many issues.
After todays update noticed the same problem. Going to go back to testing the update on the sd card and doing the update to the emmc if the update goes well.
OK - running 5.7 kernel OK.
Installed 20200625 nightly
Settings, Power, Disable automatic brightness and Disable Dim screen when inactive
Then upgrade to 5.7
(06-25-2020, 03:13 PM)Boern Wrote: I had it installed to EMMC, so I hope I will be able to restore everything by booting from SD. Can I just reinstall u-boot? What are the commands to do so?
To reinstall u-boot to the eMMC, the command is:
sudo u-boot-install-sunxi64 /dev/mmcblk2
Please let me know if it solves your problem.
(06-25-2020, 04:51 PM)dukla2000 Wrote: Settings, Power, Disable automatic brightness and Disable Dim screen when inactive
Interesting, that means the brightness scale (changed in pine64's 5.7 kernel) does not work that well for all devices... I'll have a look
I tried running
from a chroot, that just made everything worse and it wouldn't boot at all. But running it from within a fresh mobian-pinephone-20200615.img.gz installation worked.
But now I have the problems with automatic brightness. But I do have ssh-access. Can I somehow do the necessary settings from the command line?
Edit: The screen lit up for about 2 seconds every time I put in a charging cable and so I was able to make the necessary changes.
To disable auto-brightness:
gsettings set org.gnome.settings-daemon.plugins.power ambient-enabled false
To set a correct brightness value (as root)
echo 400 > /sys/class/backlight/backlight/brightness
I'm working on a new kernel version which should (hopefully) get the brightness scale right...
(06-26-2020, 08:33 AM)Boern Wrote: from a chroot, that just made everything worse and it wouldn't boot at all. But running it from within a fresh mobian-pinephone-20200615.img.gz installation worked.
yes, I wouldn't have tried that from a chroot, only from a running system (whether it runs from SD or eMMC doesn't matter)
  No touch KB after update(forky) biketool 4 1,542 12-05-2025, 01:15 AM
  trixie update poll questions suggestions j_s 5 1,869 10-22-2025, 07:14 AM
Last Post: anonymous
  how to update mobian over tor vusra 14 18,578 12-04-2024, 07:01 PM
Last Post: vusra
  No volume control after latest updates Zebulon Walton 19 19,472 09-08-2023, 08:28 AM
Last Post: jessencan
  Wifi doesn't work after update nickolas 2 4,263 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 4,477 03-17-2023, 07:26 AM
Exclamation Impossible to login since the latest update anonymous 12 14,787 02-26-2023, 01:01 PM
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 12,601 11-28-2022, 03:30 PM
  [Fixed] Phosh crashes frequently after latest updates arno_nuehm 20 23,325 10-14-2022, 05:38 PM
Last Post: Krafter
  Latest Reliable Mobian Build Confirmation Thread Katsujinken 5 6,980 09-27-2022, 08:41 AM
Last Post: Katsujinken
