X.org crashes / Debian Bulleyes
On a unstable debian install, I use libmesa from experimental and it works pretty well : no more crash using gtk app
I didn't notice the dependency on gcc10, I'll check this out tonight, but it seemed a rather simple update to me.
libgcc1 is from GCC10 in unstable.
just use the mesa-git installer to create a separate mesa install in /usr/local. it solves all of debian's 19.3.x problems AND provides better performance.
you can use the master branch or 20.0 branch. (rc3 irrc)
i made a script to help y'all...
I also encountered this crash with a fresh installation - it was especially nasty because it put lightdm into an endless loop of starting the X server, starting the greeter, X crashes, repeat...
However, installing Mesa 20.0 from experimental fixed it.  Specifically, upgrading these packages from 19.3.3-1 (unstable) to 20.0.0-1 (experimental) is sufficient to solve the crash:
libegl-mesa0
libgbm1
libgl1-mesa-dri
libglapi-mesa
libglx-mesa0
mesa-va-drivers
mesa-vdpau-drivers
mesa-vulkan-drivers
And I'm pleased to say that the display corruption problems (e.g. illegibly pixelated text) I was seeing with the stock (stretch-based) install are completely gone.
  Official Debian support moonwalkers 63 54,401 05-16-2024, 11:00 PM
Last Post: rempfer
  Debian on Pinebook Pro u974615 7 1,686 03-31-2024, 10:11 AM
Last Post: u974615
  install debian on pbp jsch 7 4,357 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 8,003 09-07-2023, 09:38 PM
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,386 07-15-2023, 02:58 PM
Last Post: u974615
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,359 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,490 12-09-2022, 05:04 AM
Last Post: ndp
  How can I install Debian? ImmyChan 1 2,227 10-19-2022, 03:09 AM
Last Post: alpopa
  when i close my laptop lid the screen doesn't turn on? (debian bullseye based) computerc 3 2,066 09-23-2022, 08:37 PM
Last Post: computerc
  Debian emmc installer db579 6 3,234 08-23-2022, 06:13 AM
Last Post: db579
