Pinebook Pro Fingerprint Magnet
#21
(11-30-2019, 01:05 AM)clover Wrote: I think its a great idea to have dbrand-esque skins for this as wells as the PinePhone! Smile
That's the goal! Big Grin  If there are any patterns/designs you see that might look good as one, let us know, and we'll see if we can adapt it. We're very close to having templates done. Once we do, I'm going to start prototyping the simpler design MrTester suggested.
#22
Can't wait to see.
Perhaps if you have some that are really liked in the community we could work out some sort of promotion.
#23
I would be down with that. I've already thought of offering any that are popular and simple enough to produce over to Pine64, to do with as you please, or to make them publicly available as ready to print/cut with advisories concerning printing and application.
#24
Honestly just a matte color (maybe the pine64blue and black) would be great. I also like the dragon skin from DBrand but it might be harder to recreate that texture.
#25
If you can, send me links to any generic designs you'd like to see adapted, or something similar produced. If the dragon skin is a scale pattern, that wouldn't be too hard to create. I'd just have to focus on one tiny portion to define it as the pattern fill.
#26
https://forums.macrumors.com/threads/dbr...19&slide=0
This link should take you to examples of the dragon skin.
#27
(12-02-2019, 05:08 PM)clover Wrote: https://forums.macrumors.com/threads/dbr...19&slide=0
Thanks!
Looking at it now, we could emulate the visual texture, but it would likely be very costly to produce skins with the actual physical texture. I'll add it to the list to look into, though!
Looked into it, it'd be easy for a phone, probably a nightmare with anything bigger than the Tab.
#28
Yea, a vinyl can be quite expensive ... unless its carbon, those are usually quite cheap.
#29
I'm thinking I can just mask off and spray PlastiDip. :-)
— Jeremiah Cornelius
  About new OS over pinebook debian voje12 1 11 44 minutes ago
  Pinebook Pro Initial Impressions kunger 443 605,066 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,473 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 549 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 422 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 414 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 341 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 846 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 926 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 8,015 12-17-2023, 09:29 PM
Last Post: insideau786
