Compiling with -j6 on the Pinebook Pro (Overheat)
I have 2 PBPs that I sometimes do a lot of compiling with.
One is from 2020.  I never used all 6 CPUs when compiling, or if I did, I throttled the two faster CPUs: due to the problem of using more power than the power supply can supply.
The other is from 2023 (or was it 2022?) and has the improved charging circuit.  I used this one the same way, because, if I use all 6 CPUs unthrottled, it will overheat and reboot.  For some reason, I thought this was just a shortcoming of this SOC.
But recently I did some short runs using full power on the 2023 model (not getting it hot enough to reboot), and I accidentally used the same configuration on the 2020 model.  I found out that, except for the expected battery depletion, the 2020 one never overheats and reboots.
Does anyone else have a newer one that overheats like this?  Or have I been dealing with a flaky PBP all along?
:wq
[ SRA accepts you ]
  Pinebook Pro Initial Impressions kunger 443 588,291 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,291 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 399 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 299 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 290 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 673 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 741 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,610 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,230 12-15-2023, 02:11 PM
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 60,207 11-20-2023, 06:22 PM
