Bricked my PineTab2 using Jumpdrive?
I tried to use Jumpdrive to write an os image to the exposed /dev/hda block device and now the tablet no longer boots. Jumpdrive always boots though and I tried "flashing" the factory default image but still no luck.
Can I somehow use Jumpdrive to restore my PineTab2 to a bootable condition?
I never received a USB/UART with my PineTab2 and shipping to USA is quite expensive so buying this would be a last resort.
(02-23-2024, 03:05 PM)jkboyd Wrote: I tried to use Jumpdrive to write an os image to the exposed /dev/hda block device and now the tablet no longer boots. Jumpdrive always boots though and I tried "flashing" the factory default image but still no luck.
I'm not much help here, but I will note that the USB/UART device is easily overlooked (by me at least). If you still have your packaging you may want to go back and look for it. As I recall, the device was tiny and crammed into a small nook where I almost didn't see it.
Good luck!
Good luck!
Thanks for the tip, but no luck finding it. I think they just to forgot to pack it and I didn't even realize it was supposed to come included with it. I had mine working for a while with PostmarketOS.
  New PineTab2 dRateNWAytORy 2 277 05-11-2024, 09:46 AM
Last Post: frtodd
  Someone is interested for a PineTab2 8GB in Mexico? genobraker 0 275 03-06-2024, 07:22 PM
Last Post: genobraker
  dd'ed Mobian, bricked? GloriousCoffee 9 2,029 02-25-2024, 05:26 AM
Last Post: fxc
  Castle Game Engine on PineTab2 now officially available michalis 1 918 12-14-2023, 12:22 AM
  PinePhone or PineBook USB-C hubs on Pinetab2? Evergreen 1 795 11-05-2023, 10:20 AM
Last Post: WEF
  Pinetab2 screen issue. screen does not power on at all bluemage 5 1,537 09-25-2023, 08:29 PM
Last Post: bluemage
  What's the MAX RAM you can install to PineTab2? Ptab2newb 2 1,070 09-12-2023, 12:38 PM
Last Post: Ptab2newb
  Booting from SD card on Pinetab2 samochimaaron 10 3,271 08-23-2023, 09:38 AM
Last Post: diederik
  Pinetab2 without Wifi a comfort extra? Schlucker 8 3,377 07-14-2023, 03:09 AM
Last Post: gregb49
  PineTab2 virtual keyboard: symbols instead of numbers clemfandango 5 2,165 07-12-2023, 05:32 AM
Last Post: mtomaschett
