Gentoo on Pinebook Pro RELEASE
#41
I have a rockpro64, ive built a gentoo Iinux on debian-arm64 , usb emmc, as chroot.
64 was max , however i have to replace laptop m.2... (i bought i mini adapter and ribbon adapter to stuff an m.2 into a playbox case.
Touchscreen drivers are a rarity but doable pia, screen mirroring to hdmi/dsp0-ts)
For a demo feild pentester contraption..
Sdcard to emmc adapter so.. as sdcards stresses out faster.. or need endurance models.
Emmc are more akin to m.2 and far more re
My emmc is outa space so opportune time to move the build mess to 550 m.2.
Now 128 emmc are on menu so 2 might be good.
Multi instace binhost, will keep packages, with different build flags but also eats space.
And can prepare, the manjaro root fs , cleave out / /boot /boot/efi symbolic link some files on /boot to /efi ..
I have grub with uefi, uboot zfs etc etc etc.,
Newer uboot can load uefi. Ie grub-efi as intermediate boot, pick a kernel, or even refind..
Pick kernel/os on m.2 emmc, sd.. usb etc.
So preparing a chroot is quite doable.
Sakaki's Rpi4 binhost is helping, but be warned, many are opengl+gles2 or majority -gles2..
However many packages wont build , but her/his crossdev build pkgs can the be rebuilt..
+/- features.. xfce is in tree.
https://github.com/necrose99/gentoo-binhost
Upstream has a few older packages but more on server targets.
Ive added a few pine64 rockpro64, rock64, and the pine book pro files as binaries.
And PENTOO LINUX, my original purpose.
Ports of metasploit, gcc crossdev's etc.
Scaleway hosting, 35 usd/32 E's a mo 8-16 gigs , and dep on virtual cores, debian host 256 gigs of mounted chroot.
Speed of compiles is greatly improved.
Make linux j8 etc. Useful if fakeroot = ./my-kernel
-C to chroot on tar xz > kernel.txz
Most kernels, gentoo, panfrost sorces , Sabayon, pentoo, make all modules, then allyess
Fix config, sysfs v2 depreciated in general setup, N as in hell No.
Next i need to grepout debugging items in config.
Aufs5 sources. Or stand alone async-emerge needs it. , cloveros a gentoo live has a reliable aufs5 patching bit in gitgud , buildroot scripts.
https://github.com/alexdux/async-emerge-overlay
Uses chroot in tmpfs/ramdrive to remake world.
Drops bins in /packages, ie kde qt5-x.y.z x.y.35 out deps hell no letgo...
Upgrade qt stack revdep-rebuild wala.
Since i care to run possible 3x arm64 devices, id rather go failsafe on kernel.
Scaleway, ill need to renew soon i suppose, and docker is good for building and reliable.
Sent from my SM-N960U using Tapatalk
Gentoo on Pinebook Pro RELEASE - by jannik2099 - 01-13-2020, 10:47 AM
RE: Gentoo on Pinebook Pro RELEASE - by Arwen - 01-13-2020, 07:12 PM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-15-2020, 11:20 AM
RE: Gentoo on Pinebook Pro RELEASE - by VoxUnius - 01-15-2020, 05:34 PM
RE: Gentoo on Pinebook Pro RELEASE - by VoxUnius - 01-18-2020, 05:13 PM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-19-2020, 07:57 AM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-21-2020, 12:34 AM
RE: Gentoo on Pinebook Pro RELEASE - by as400 - 01-21-2020, 01:55 AM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-21-2020, 11:59 PM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-23-2020, 01:31 AM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-24-2020, 09:13 AM
RE: Gentoo on Pinebook Pro RELEASE - by Arwen - 01-29-2020, 07:38 PM
RE: Gentoo on Pinebook Pro RELEASE - by madalin - 02-01-2020, 11:00 AM
RE: Gentoo on Pinebook Pro RELEASE - by madalin - 02-02-2020, 09:44 AM
RE: Gentoo on Pinebook Pro RELEASE - by PakoSt - 02-04-2020, 09:59 AM
RE: Gentoo on Pinebook Pro RELEASE - by necrose99 - 02-12-2020, 05:59 PM
RE: Gentoo on Pinebook Pro RELEASE - by necrose99 - 02-15-2020, 07:45 PM
RE: Gentoo on Pinebook Pro RELEASE - by larsgn - 02-25-2020, 08:58 AM
Gentoo on Pinebook Pro RELEASE - by necrose99 - 03-01-2020, 10:05 AM
RE: Gentoo on Pinebook Pro RELEASE - by rjraymond - 09-18-2020, 11:06 PM
RE: Gentoo on Pinebook Pro RELEASE - by kuleszdl - 01-02-2021, 10:05 PM
RE: Gentoo on Pinebook Pro RELEASE - by wdt - 01-03-2021, 06:21 AM
RE: Gentoo on Pinebook Pro RELEASE - by alchemist - 06-08-2021, 12:45 PM
RE: Gentoo on Pinebook Pro RELEASE - by glesker - 10-05-2021, 08:16 AM
RE: Gentoo on Pinebook Pro RELEASE - by kebab - 11-26-2023, 06:36 PM
RE: Gentoo on Pinebook Pro RELEASE - by tllim - 12-08-2023, 11:25 PM
  Debian on Pinebook Pro u974615 7 1,062 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,622 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,163 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,237 12-11-2023, 03:47 AM
Last Post: calinb
  Boot Order in Pinebook Pro food 8 1,263 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,304 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,489 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,596 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 667 07-13-2023, 05:21 PM
Last Post: owaspfap
  OpenCL on pinebook Pro Bram 2 997 06-30-2023, 08:50 PM
Last Post: scurrvy2020
