OpenCL on pinebook Pro
I am running Armbian 23.02.2 and I am trying to use OpenCL.
Using clinfo, it turns out that there are no installed driver.
$ clinfo
Number of platforms                              0
Where can I obtain an OpenCL driver for the Pinebook PRO?
If I remember correctly there is no OpenCL support in the open-source Panfrost drivers (yet). Maybe this will change with Rusticl though.
The closed-source Mali drivers can do OpenCL I think, but they are tied to some old Kernel version or so. Never tried them.
there is some support in rusticl https://mesamatrix.net/
you need to set the driver and opencl version with environment variables. I have tried it with darktable and got garbled images, so there are some issues.
  Debian on Pinebook Pro u974615 7 1,038 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,611 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,153 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,232 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 88,984 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,246 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,285 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,487 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,588 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 664 07-13-2023, 05:21 PM
Last Post: owaspfap
