Gentoo on Pinebook Pro RELEASE
Hello everyone
UPDATE: everything necessary for a full release should now be packaged. After tidying up stuff and providing up to date tarballs, we should officially be out of beta!
Today marks the beta release of my Gentoo install script. This is NOT an image you flash to an SD but rather a script that modifies a Gentoo tarball for the Pinebook Pro. You'll have to do the usual setup yourself as is Gentoo tradition, but the Pinebook Pro specifics like Kernel and Firmware are (mostly) handled by the script.
Instructions are in the GitHub README, please report bugs and questions here. You can also find me on the PINE64 Discord.
The script takes about 20 60 minutes to run on the pbp, compiling the kernel is another ~90 minutes. This means you should have a working Gentoo install after less than three hours, plus some time spent reading the Handbook.
Link to GitHub: https://github.com/Jannik2099/gentoo-pinebookpro
Status of this release:
Most things should behave the same as in Manjaro since this uses the Manjaro Kernel. This means we have working wifi, bluetooth, GPU acceleration.
The mali blob drivers are not supported since the dts is incompatible, this uses panfrost.
Tested Desktop environments are KDE Plasma and sway. Both work without issue.
There's no reason to believe that other DEs might be broken, I simply don't have the time to compile all of them.
This script is compatible with both systemd and OpenRC tarballs.
This script is compatible with glibc and musl tarballs.
The Qt libraries are configured to use the gles2 backend, this is significantly faster and more stable in my experience. However Krita and Digikam are unavailable as a result. You can use them if you disable the gles2 backend.
A huge shoutout to the Manjaro team for their help and insights, this project would not have been possible without you!
With that being said, enjoy and please report all bugs, suggestions and nitpicks!
Gentoo on Pinebook Pro RELEASE - by jannik2099 - 01-13-2020, 10:47 AM
RE: Gentoo on Pinebook Pro RELEASE - by Arwen - 01-13-2020, 07:12 PM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-15-2020, 11:20 AM
RE: Gentoo on Pinebook Pro RELEASE - by VoxUnius - 01-15-2020, 05:34 PM
RE: Gentoo on Pinebook Pro RELEASE - by VoxUnius - 01-18-2020, 05:13 PM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-19-2020, 07:57 AM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-21-2020, 12:34 AM
RE: Gentoo on Pinebook Pro RELEASE - by as400 - 01-21-2020, 01:55 AM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-21-2020, 11:59 PM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-23-2020, 01:31 AM
RE: Gentoo on Pinebook Pro RELEASE - by delcaran - 01-24-2020, 09:13 AM
RE: Gentoo on Pinebook Pro RELEASE - by Arwen - 01-29-2020, 07:38 PM
RE: Gentoo on Pinebook Pro RELEASE - by madalin - 02-01-2020, 11:00 AM
RE: Gentoo on Pinebook Pro RELEASE - by madalin - 02-02-2020, 09:44 AM
RE: Gentoo on Pinebook Pro RELEASE - by PakoSt - 02-04-2020, 09:59 AM
RE: Gentoo on Pinebook Pro RELEASE - by necrose99 - 02-12-2020, 05:59 PM
RE: Gentoo on Pinebook Pro RELEASE - by necrose99 - 02-15-2020, 07:45 PM
RE: Gentoo on Pinebook Pro RELEASE - by larsgn - 02-25-2020, 08:58 AM
Gentoo on Pinebook Pro RELEASE - by necrose99 - 03-01-2020, 10:05 AM
RE: Gentoo on Pinebook Pro RELEASE - by rjraymond - 09-18-2020, 11:06 PM
RE: Gentoo on Pinebook Pro RELEASE - by kuleszdl - 01-02-2021, 10:05 PM
RE: Gentoo on Pinebook Pro RELEASE - by wdt - 01-03-2021, 06:21 AM
RE: Gentoo on Pinebook Pro RELEASE - by alchemist - 06-08-2021, 12:45 PM
RE: Gentoo on Pinebook Pro RELEASE - by glesker - 10-05-2021, 08:16 AM
RE: Gentoo on Pinebook Pro RELEASE - by kebab - 11-26-2023, 06:36 PM
RE: Gentoo on Pinebook Pro RELEASE - by tllim - 12-08-2023, 11:25 PM
  Debian on Pinebook Pro u974615 7 1,191 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,688 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,196 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,279 12-11-2023, 03:47 AM
Last Post: calinb
  Boot Order in Pinebook Pro food 8 1,296 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,413 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,519 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,619 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 673 07-13-2023, 05:21 PM
Last Post: owaspfap
  OpenCL on pinebook Pro Bram 2 1,009 06-30-2023, 08:50 PM
Last Post: scurrvy2020
