Restore default Debian system
#44
(02-03-2020, 01:14 PM)uby89 Wrote: Eh eh thanks. I did a lot of reading, and my understanding is that with emmc disabled, and a sd card inserted with an OS with uboot on it should boot.
But it doesn't, which is slightly worry me.
I also tried re-flashing uboot on my current debian OEM on the emmc, checking the ribbon cable connecting the sd card. No luck.
I might have to wait for the usb adapter, but it does bother me that I should be able to boot from sd... and I could sort my emmc from there.
I've encountered an issue with similar symptoms. Have you tried another kind of image on the SD card with the bad eMMC still on? I had my bad eMMC (Manjaro) boot to login on a Debian SD but the Manjaro SD wouldn't except with a good Debian eMMC.
Restore default Debian system - by perceg - 11-06-2019, 11:29 PM
RE: Restore default Debian system - by Blackr0se - 11-07-2019, 02:19 AM
RE: Restore default Debian system - by fire219 - 11-07-2019, 08:29 AM
RE: Restore default Debian system - by bcnaz - 11-07-2019, 08:37 AM
RE: Restore default Debian system - by fire219 - 11-07-2019, 09:47 AM
RE: Restore default Debian system - by perceg - 11-07-2019, 12:10 PM
RE: Restore default Debian system - by perceg - 11-07-2019, 05:27 PM
RE: Restore default Debian system - by evj - 02-06-2020, 11:18 AM
RE: Restore default Debian system - by bcnaz - 11-07-2019, 11:31 PM
RE: Restore default Debian system - by xircledev - 11-08-2019, 12:17 AM
RE: Restore default Debian system - by perceg - 11-08-2019, 05:15 AM
RE: Restore default Debian system - by zaius - 11-08-2019, 06:33 AM
RE: Restore default Debian system - by FeMike - 02-01-2020, 05:39 AM
RE: Restore default Debian system - by uby89 - 02-03-2020, 03:27 AM
RE: Restore default Debian system - by MIchael - 02-03-2020, 06:35 AM
RE: Restore default Debian system - by uby89 - 02-03-2020, 08:13 AM
RE: Restore default Debian system - by MIchael - 02-03-2020, 11:23 AM
RE: Restore default Debian system - by bcnaz - 02-03-2020, 01:04 PM
RE: Restore default Debian system - by uby89 - 02-03-2020, 01:14 PM
RE: Restore default Debian system - by Thovthe - 02-20-2020, 05:28 PM
RE: Restore default Debian system - by PineFan - 02-03-2020, 07:39 PM
RE: Restore default Debian system - by MIchael - 02-04-2020, 07:19 AM
RE: Restore default Debian system - by Thovthe - 02-20-2020, 05:21 PM
RE: Restore default Debian system - by bcnaz - 11-08-2019, 05:36 PM
RE: Restore default Debian system - by bcnaz - 11-08-2019, 12:40 AM
RE: Restore default Debian system - by markh66509 - 12-29-2019, 08:47 AM
RE: Restore default Debian system - by markh66509 - 01-01-2020, 07:59 PM
RE: Restore default Debian system - by bcnaz - 01-01-2020, 10:39 PM
RE: Restore default Debian system - by bcnaz - 01-02-2020, 12:00 AM
RE: Restore default Debian system - by xircledev - 01-06-2020, 08:05 PM
RE: Restore default Debian system - by pmb_nl - 01-26-2020, 03:32 PM
RE: Restore default Debian system - by binholz - 01-28-2020, 05:44 AM
RE: Restore default Debian system - by binholz - 01-28-2020, 11:28 AM
RE: Restore default Debian system - by MIchael - 01-28-2020, 06:06 PM
RE: Restore default Debian system - by bcnaz - 02-03-2020, 01:34 PM
RE: Restore default Debian system - by uby89 - 02-04-2020, 03:21 PM
RE: Restore default Debian system - by weskerfoot - 02-06-2020, 12:24 AM
RE: Restore default Debian system - by weskerfoot - 02-06-2020, 10:01 AM
  Debian on Pinebook Pro u974615 7 1,372 03-31-2024, 10:11 AM
Last Post: u974615
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 381 03-01-2024, 06:46 PM
Last Post: Puckla
  Nethunter default password failed lamlarryyyy 0 385 11-23-2023, 02:48 AM
Last Post: lamlarryyyy
  install debian on pbp jsch 7 4,182 11-22-2023, 04:22 PM
Last Post: TRS-80
  Fedora 36 -> 37 upgrade kills system tydeman 0 485 10-28-2023, 09:53 AM
Last Post: tydeman
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,658 09-07-2023, 09:38 PM
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,187 07-15-2023, 02:58 PM
Last Post: u974615
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,309 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,388 12-09-2022, 05:04 AM
Last Post: ndp
  How can I install Debian? ImmyChan 1 2,097 10-19-2022, 03:09 AM
Last Post: alpopa
