(12-06-2019, 04:09 PM)gristle Wrote:
(12-06-2019, 03:25 PM)neilman Wrote:
(12-06-2019, 03:06 PM)gristle Wrote: I rarley post anywhere, apologies if I make some mistakes. I felt compelled to post today to say thanks to the people that made the pbp happen.
The teams that work on hardware/software (thats where the magic happens!), the admins that coordinate efforts and manage logistics (thats where the magic happens!) and to all the people who regularly (and some random) post the solutions and ideas that keep me coming back here(this is where the magic continues to happen!).
So THANKS! and GOOD JOB!
This is not really an initial impression, more of a "I've had some time and know what it's capable of" impression.
I love the Pine Book Pro! It's exactly what i wanted and more than I expected. It reminds me of my acer aspire one when it still worked.
I had forgotten how much i liked that machine, and though i wasnt looking for it, I found a replacement.
I wanted a machince i can dedicate to learning linux on and not get lazy and boot windows on, also learn more about arm and learn to bend sbc's to my will without having to hook keyboards and monitors to it. As it turns out its also a great laptop!
I have had some of the problems i see posted here, most have been resolved by updates or helpful post. This may be a dumb suggestion but to the people having wifi problems, I can't swear this fixed my issue because it's been a while since i made any changes but setting ipv6 to ignore in the edit connection gui seemed to help my issue. I have to do this at work from time to time (windows). I have to turn it back on for captive portal in hotels and such. I have a vague notion about why this may help in my case, its more about the network or router than pbp. Ofcourse this wont help if your antenna is bad and you've measured signal strength with something more legible than the tray icon, and pulled the antenna connection and didn't see a change in signal strength.
I have the no sound in firefox issue and saw the fix for that. Will get to that shortly.
One thing is my bluetooth mouse wont reconnect. The device monitor shows it's connected  after reboot, gives link quality info that update and changes but doesnt resopnd to mouse input. Any suggestions on where to look? Pretend I only know enough linux to be dangerous if you have a suggestion, I'm actually pretty good at it. This is only my third unplanned reinstall after all. That reminds me, How can I make a backup, I like what i have now. Do i just RTFM?  Smile
I had the same problem with my Bluetooth mouse - it was paired correctly, worked, rebooted, then still listed but wouldn't work.
Turned out to be a simple configuration issue - check the device entry for the mouse - is there a yellow star symbol in the status bar of the device window?
Clicking on that star symbol flags the mouse as a "trusted" device - and the star "goes grey" - mouse works every time now Smile
Oh, well yeah, I mean, thats fine if you want to fix it the easy way.(facepalm)
That worked! Simple and obvious now. I was looking for a more complicated answer cause, linux.
Thanks!
If its any consolation I only found the answer by accident myself - I wondered what the star was for and "sucked it and saw it worked" - serendipity Big Grin
Pinebook Pro Initial Impressions - by kunger - 10-01-2019, 04:03 PM
RE: Pinebook Pro Initial Impressions - by Luke - 10-01-2019, 04:24 PM
RE: Pinebook Pro Initial Impressions - by danielt - 10-03-2019, 09:26 AM
RE: Pinebook Pro Initial Impressions - by bcnaz - 11-08-2019, 09:06 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 11-10-2019, 12:59 PM
RE: Pinebook Pro Initial Impressions - by odinson - 10-01-2019, 05:17 PM
RE: Pinebook Pro Initial Impressions - by Luke - 10-01-2019, 05:49 PM
RE: Pinebook Pro Initial Impressions - by jabo - 10-01-2019, 06:28 PM
RE: Pinebook Pro Initial Impressions - by Wizzard - 10-02-2019, 05:51 AM
RE: Pinebook Pro Initial Impressions - by kunger - 10-02-2019, 07:00 AM
RE: Pinebook Pro Initial Impressions - by Wizzard - 10-02-2019, 07:09 AM
RE: Pinebook Pro Initial Impressions - by neilman - 10-02-2019, 07:09 AM
RE: Pinebook Pro Initial Impressions - by PakoSt - 10-02-2019, 07:52 AM
RE: Pinebook Pro Initial Impressions - by kunger - 10-02-2019, 07:22 AM
RE: Pinebook Pro Initial Impressions - by jabo - 10-02-2019, 07:47 AM
RE: Pinebook Pro Initial Impressions - by neilman - 10-02-2019, 07:57 AM
RE: Pinebook Pro Initial Impressions - by Luke - 10-02-2019, 08:38 AM
RE: Pinebook Pro Initial Impressions - by neilman - 10-02-2019, 09:08 AM
RE: Pinebook Pro Initial Impressions - by Luke - 10-02-2019, 09:24 AM
RE: Pinebook Pro Initial Impressions - by kaylios - 10-02-2019, 02:27 PM
RE: Pinebook Pro Initial Impressions - by neilman - 10-02-2019, 09:41 AM
RE: Pinebook Pro Initial Impressions - by Luke - 10-02-2019, 09:58 AM
RE: Pinebook Pro Initial Impressions - by neilman - 10-02-2019, 03:23 PM
RE: Pinebook Pro Initial Impressions - by kaylios - 10-03-2019, 02:26 AM
RE: Pinebook Pro Initial Impressions - by Omli - 10-02-2019, 04:07 PM
RE: Pinebook Pro Initial Impressions - by venix1 - 10-02-2019, 10:26 PM
RE: Pinebook Pro Initial Impressions - by zaius - 10-03-2019, 12:42 PM
RE: Pinebook Pro Initial Impressions - by kunger - 10-02-2019, 05:56 PM
RE: Pinebook Pro Initial Impressions - by neilman - 10-03-2019, 06:36 AM
RE: Pinebook Pro Initial Impressions - by PakoSt - 10-03-2019, 07:08 AM
RE: Pinebook Pro Initial Impressions - by kaylios - 10-03-2019, 07:30 AM
RE: Pinebook Pro Initial Impressions - by neilman - 10-03-2019, 07:53 AM
RE: Pinebook Pro Initial Impressions - by danielt - 10-03-2019, 03:19 PM
RE: Pinebook Pro Initial Impressions - by Luke - 10-03-2019, 03:21 PM
RE: Pinebook Pro Initial Impressions - by Luke - 10-03-2019, 08:23 AM
RE: Pinebook Pro Initial Impressions - by Omli - 10-04-2019, 06:22 PM
RE: Pinebook Pro Initial Impressions - by neilman - 10-03-2019, 09:33 AM
RE: Pinebook Pro Initial Impressions - by Luke - 10-03-2019, 09:39 AM
RE: Pinebook Pro Initial Impressions - by neilman - 10-03-2019, 09:45 AM
RE: Pinebook Pro Initial Impressions - by Luke - 10-03-2019, 10:07 AM
RE: Pinebook Pro Initial Impressions - by neilman - 10-03-2019, 11:01 AM
RE: Pinebook Pro Initial Impressions - by kunger - 10-03-2019, 01:34 PM
RE: Pinebook Pro Initial Impressions - by danielt - 10-03-2019, 10:14 AM
RE: Pinebook Pro Initial Impressions - by Luke - 10-03-2019, 01:38 PM
RE: Pinebook Pro Initial Impressions - by neilman - 10-03-2019, 01:58 PM
RE: Pinebook Pro Initial Impressions - by Luke - 10-03-2019, 02:05 PM
RE: Pinebook Pro Initial Impressions - by neilman - 10-03-2019, 05:08 PM
RE: Pinebook Pro Initial Impressions - by Arwen - 10-03-2019, 05:28 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 10-03-2019, 08:49 PM
RE: Pinebook Pro Initial Impressions - by Luke - 10-03-2019, 06:04 PM
RE: Pinebook Pro Initial Impressions - by zaius - 10-04-2019, 12:51 PM
RE: Pinebook Pro Initial Impressions - by tsago - 10-05-2019, 03:10 AM
RE: Pinebook Pro Initial Impressions - by PakoSt - 10-08-2019, 05:22 AM
RE: Pinebook Pro Initial Impressions - by zaius - 10-19-2019, 01:03 PM
RE: Pinebook Pro Initial Impressions - by Luke - 10-19-2019, 04:41 PM
RE: Pinebook Pro Initial Impressions - by zaius - 10-19-2019, 05:34 PM
RE: Pinebook Pro Initial Impressions - by Luke - 10-19-2019, 06:19 PM
RE: Pinebook Pro Initial Impressions - by zaius - 10-22-2019, 04:54 PM
RE: Pinebook Pro Initial Impressions - by zaius - 10-23-2019, 06:10 AM
RE: Pinebook Pro Initial Impressions - by Luke - 10-23-2019, 05:57 PM
RE: Pinebook Pro Initial Impressions - by Wizzard - 10-24-2019, 12:39 AM
RE: Pinebook Pro Initial Impressions - by tsago - 10-24-2019, 12:03 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 10-27-2019, 06:14 PM
RE: Pinebook Pro Initial Impressions - by fire219 - 10-26-2019, 10:33 AM
RE: Pinebook Pro Initial Impressions - by bcnaz - 10-28-2019, 11:49 AM
RE: Pinebook Pro Initial Impressions - by Wizzard - 10-31-2019, 03:13 AM
RE: Pinebook Pro Initial Impressions - by Arwen - 10-31-2019, 04:50 PM
RE: Pinebook Pro Initial Impressions - by hmuller - 10-31-2019, 09:20 PM
RE: Pinebook Pro Initial Impressions - by Wizzard - 11-01-2019, 06:19 AM
RE: Pinebook Pro Initial Impressions - by richfm - 11-01-2019, 07:56 AM
RE: Pinebook Pro Initial Impressions - by noisy - 11-01-2019, 08:03 AM
RE: Pinebook Pro Initial Impressions - by neilman - 11-01-2019, 08:35 AM
RE: Pinebook Pro Initial Impressions - by richfm - 11-01-2019, 09:04 AM
RE: Pinebook Pro Initial Impressions - by neilman - 11-01-2019, 09:22 AM
RE: Pinebook Pro Initial Impressions - by richfm - 11-01-2019, 11:18 AM
Pinebook Pro Initial Impressions - by Wizzard - 11-01-2019, 08:03 AM
RE: Pinebook Pro Initial Impressions - by bcnaz - 11-01-2019, 09:48 AM
RE: Pinebook Pro Initial Impressions - by zaius - 11-01-2019, 04:26 PM
RE: Pinebook Pro Initial Impressions - by Luke - 11-01-2019, 05:33 PM
RE: Pinebook Pro Initial Impressions - by Luke - 11-01-2019, 06:26 PM
RE: Pinebook Pro Initial Impressions - by mspohr - 11-01-2019, 07:23 PM
RE: Pinebook Pro Initial Impressions - by neilman - 11-01-2019, 07:37 PM
RE: Pinebook Pro Initial Impressions - by sundog - 11-01-2019, 09:42 PM
RE: Pinebook Pro Initial Impressions - by hmuller - 11-02-2019, 05:08 AM
RE: Pinebook Pro Initial Impressions - by richfm - 11-02-2019, 08:42 AM
RE: Pinebook Pro Initial Impressions - by richfm - 11-05-2019, 08:49 AM
RE: Pinebook Pro Initial Impressions - by richfm - 11-05-2019, 09:47 PM
RE: Pinebook Pro Initial Impressions - by richfm - 11-06-2019, 09:20 AM
RE: Pinebook Pro Initial Impressions - by richfm - 11-06-2019, 01:41 PM
RE: Pinebook Pro Initial Impressions - by richfm - 11-06-2019, 02:02 PM
RE: Pinebook Pro Initial Impressions - by richfm - 11-08-2019, 12:06 PM
RE: Pinebook Pro Initial Impressions - by zaius - 11-02-2019, 12:49 PM
RE: Pinebook Pro Initial Impressions - by mattjb - 11-02-2019, 06:32 AM
RE: Pinebook Pro Initial Impressions - by mattjb - 11-02-2019, 02:34 PM
RE: Pinebook Pro Initial Impressions - by mspohr - 11-02-2019, 09:12 AM
RE: Pinebook Pro Initial Impressions - by embhorn - 11-02-2019, 12:32 PM
RE: Pinebook Pro Initial Impressions - by JayM - 11-02-2019, 10:15 AM
RE: Pinebook Pro Initial Impressions - by mspohr - 11-03-2019, 11:10 AM
I am impressed - by Kicou - 11-04-2019, 06:33 AM
RE: Pinebook Pro Initial Impressions - by m80 - 11-04-2019, 09:59 AM
RE: Pinebook Pro Initial Impressions - by m80 - 11-04-2019, 02:50 PM
RE: Pinebook Pro Initial Impressions - by richfm - 11-04-2019, 03:50 PM
RE: Pinebook Pro Initial Impressions - by nearsky - 11-04-2019, 12:25 PM
RE: Pinebook Pro Initial Impressions - by richfm - 11-05-2019, 09:51 AM
RE: Pinebook Pro Initial Impressions - by zaius - 11-05-2019, 11:54 AM
RE: Pinebook Pro Initial Impressions - by richfm - 11-05-2019, 02:04 PM
RE: Pinebook Pro Initial Impressions - by zaius - 11-06-2019, 07:09 AM
RE: Pinebook Pro Initial Impressions - by Nappael - 11-05-2019, 05:04 PM
RE: Pinebook Pro Initial Impressions - by stanski - 11-06-2019, 12:02 PM
RE: Pinebook Pro Initial Impressions - by Depau - 11-07-2019, 06:48 AM
RE: Pinebook Pro Initial Impressions - by zaius - 11-07-2019, 07:44 AM
RE: Pinebook Pro Initial Impressions - by Depau - 11-07-2019, 08:07 AM
RE: Pinebook Pro Initial Impressions - by Depau - 11-07-2019, 11:46 AM
RE: Pinebook Pro Initial Impressions - by bcnaz - 11-08-2019, 09:19 PM
RE: Pinebook Pro Initial Impressions - by tgrauss - 11-09-2019, 03:08 AM
RE: Pinebook Pro Initial Impressions - by MC68060 - 11-09-2019, 02:15 PM
RE: Pinebook Pro Initial Impressions - by Arwen - 11-10-2019, 03:01 PM
RE: Pinebook Pro Initial Impressions - by odinson - 11-11-2019, 11:50 PM
RE: Pinebook Pro Initial Impressions - by pnts-se - 11-12-2019, 05:39 AM
RE: Pinebook Pro Initial Impressions - by r59vde - 11-12-2019, 03:35 PM
RE: Pinebook Pro Initial Impressions - by Nappael - 11-15-2019, 06:07 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 11-16-2019, 01:32 PM
RE: Pinebook Pro Initial Impressions - by Nappael - 11-18-2019, 05:07 AM
RE: Pinebook Pro Initial Impressions - by enip - 11-16-2019, 09:22 AM
RE: Pinebook Pro Initial Impressions - by SuperUJ - 11-16-2019, 05:22 PM
RE: Pinebook Pro Initial Impressions - by jiyong - 11-18-2019, 03:30 PM
RE: Pinebook Pro Initial Impressions - by jiyong - 11-19-2019, 03:39 PM
RE: Pinebook Pro Initial Impressions - by Kochise - 11-19-2019, 02:57 PM
RE: Pinebook Pro Initial Impressions - by Luke - 11-23-2019, 06:22 PM
RE: Pinebook Pro Initial Impressions - by Luke - 11-29-2019, 01:00 PM
RE: Pinebook Pro Initial Impressions - by Luke - 11-29-2019, 02:55 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 11-26-2019, 12:56 PM
video of wifi performance on PBP - by richfm - 11-27-2019, 12:19 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 11-27-2019, 12:33 PM
RE: Pinebook Pro Initial Impressions - by richfm - 11-27-2019, 04:30 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 11-27-2019, 08:44 PM
RE: Pinebook Pro Initial Impressions - by richfm - 11-28-2019, 08:26 AM
RE: Pinebook Pro Initial Impressions - by bcnaz - 11-28-2019, 10:19 AM
RE: Pinebook Pro Initial Impressions - by richfm - 11-28-2019, 11:05 AM
RE: Pinebook Pro Initial Impressions - by Arwen - 11-28-2019, 03:19 PM
RE: Pinebook Pro Initial Impressions - by richfm - 11-30-2019, 09:11 AM
RE: Pinebook Pro Initial Impressions - by ndp - 11-28-2019, 09:45 AM
RE: Pinebook Pro Initial Impressions - by Arwen - 11-30-2019, 10:09 AM
RE: Pinebook Pro Initial Impressions - by richfm - 11-30-2019, 03:30 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 11-30-2019, 04:14 PM
RE: Pinebook Pro Initial Impressions - by richfm - 12-01-2019, 08:18 AM
RE: Pinebook Pro Initial Impressions - by bcnaz - 12-03-2019, 02:38 PM
RE: Pinebook Pro Initial Impressions - by Kochise - 12-04-2019, 03:38 AM
RE: Pinebook Pro Initial Impressions - by richfm - 12-04-2019, 09:12 AM
RE: Pinebook Pro Initial Impressions - by Kochise - 12-04-2019, 11:10 AM
RE: Pinebook Pro Initial Impressions - by gristle - 12-06-2019, 03:06 PM
RE: Pinebook Pro Initial Impressions - by neilman - 12-06-2019, 03:25 PM
RE: Pinebook Pro Initial Impressions - by gristle - 12-06-2019, 04:09 PM
RE: Pinebook Pro Initial Impressions - by neilman - 12-06-2019, 04:43 PM
RE: Pinebook Pro Initial Impressions - by Arwen - 12-06-2019, 05:01 PM
RE: Pinebook Pro Initial Impressions - by Arwen - 12-07-2019, 04:50 PM
RE: Pinebook Pro Initial Impressions - by MrRobot - 12-09-2019, 02:29 PM
RE: Pinebook Pro Initial Impressions - by z4v4l - 12-19-2019, 02:05 PM
RE: Pinebook Pro Initial Impressions - by Kochise - 12-19-2019, 01:40 PM
RE: Pinebook Pro Initial Impressions - by Arwen - 12-20-2019, 08:31 PM
RE: Pinebook Pro Initial Impressions - by abdel - 12-21-2019, 10:17 AM
Pinebook Pro Initial Impressions - by balder - 12-21-2019, 11:09 AM
RE: Pinebook Pro Initial Impressions - by abdel - 12-21-2019, 11:34 AM
RE: Pinebook Pro Initial Impressions - by 8jef - 12-23-2019, 01:25 PM
RE: Pinebook Pro Initial Impressions - by 8jef - 12-23-2019, 10:02 PM
RE: Pinebook Pro Initial Impressions - by Twix166 - 12-30-2019, 04:28 AM
RE: Pinebook Pro Initial Impressions - by Twix166 - 12-31-2019, 12:22 PM
RE: Pinebook Pro Initial Impressions - by Twix166 - 01-03-2020, 12:53 PM
RE: Pinebook Pro Initial Impressions - by giav - 12-30-2019, 08:39 AM
RE: Pinebook Pro Initial Impressions - by neilman - 12-30-2019, 09:08 AM
RE: Pinebook Pro Initial Impressions - by bcnaz - 12-31-2019, 02:43 AM
RE: Pinebook Pro Initial Impressions - by whinsch - 01-03-2020, 09:10 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 01-03-2020, 09:15 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 01-07-2020, 05:34 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 01-09-2020, 09:15 AM
RE: Pinebook Pro Initial Impressions - by bcnaz - 01-09-2020, 04:06 PM
RE: Pinebook Pro Initial Impressions - by noahvg - 01-09-2020, 02:24 PM
RE: Pinebook Pro Initial Impressions - by Luke - 01-09-2020, 02:49 PM
RE: Pinebook Pro Initial Impressions - by Arwen - 01-10-2020, 06:03 AM
RE: Pinebook Pro Initial Impressions - by rossk - 01-10-2020, 03:02 PM
RE: Pinebook Pro Initial Impressions - by gillham - 01-12-2020, 01:33 AM
RE: Pinebook Pro Initial Impressions - by amp - 01-13-2020, 02:28 AM
RE: Pinebook Pro Initial Impressions - by rleasle - 01-18-2020, 08:49 AM
RE: Pinebook Pro Initial Impressions - by Wizzard - 01-12-2020, 01:46 PM
RE: Pinebook Pro Initial Impressions - by fpex73 - 01-13-2020, 06:22 AM
RE: Pinebook Pro Initial Impressions - by Luke - 01-13-2020, 06:38 AM
RE: Pinebook Pro Initial Impressions - by fpex73 - 01-13-2020, 06:46 AM
RE: Pinebook Pro Initial Impressions - by Luke - 01-13-2020, 08:00 AM
RE: Pinebook Pro Initial Impressions - by fpex73 - 01-13-2020, 09:20 AM
RE: Pinebook Pro Initial Impressions - by Arwen - 01-13-2020, 05:57 PM
RE: Pinebook Pro Initial Impressions - by fpex73 - 01-14-2020, 12:14 AM
RE: Pinebook Pro Initial Impressions - by Arwen - 01-14-2020, 07:57 AM
RE: Pinebook Pro Initial Impressions - by ab1jx - 01-14-2020, 10:58 AM
Pinebook Pro Initial Impressions - by jsfrederick - 01-14-2020, 07:52 PM
RE: Pinebook Pro Initial Impressions - by amooke - 01-14-2020, 08:24 PM
RE: Pinebook Pro Initial Impressions - by Arwen - 01-14-2020, 08:59 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 01-14-2020, 11:02 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 01-15-2020, 01:36 AM
RE: Pinebook Pro Initial Impressions - by bcnaz - 01-15-2020, 03:41 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 01-15-2020, 04:12 PM
RE: Pinebook Pro Initial Impressions - by 8jef - 01-15-2020, 07:54 PM
RE: Pinebook Pro Initial Impressions - by fortran - 01-15-2020, 08:32 PM
RE: Pinebook Pro Initial Impressions - by 8jef - 01-15-2020, 09:17 PM
RE: Pinebook Pro Initial Impressions - by fortran - 01-17-2020, 01:17 PM
RE: Pinebook Pro Initial Impressions - by fortran - 01-18-2020, 12:49 PM
RE: Pinebook Pro Initial Impressions - by Kochise - 01-18-2020, 01:32 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 01-18-2020, 02:36 PM
RE: Pinebook Pro Initial Impressions - by rossk - 01-21-2020, 07:52 AM
RE: Pinebook Pro Initial Impressions - by Syg - 01-21-2020, 10:34 AM
RE: Pinebook Pro Initial Impressions - by avill - 01-21-2020, 07:46 PM
RE: Pinebook Pro Initial Impressions - by Luke - 01-23-2020, 08:16 AM
RE: Pinebook Pro Initial Impressions - by wove - 01-31-2020, 08:21 AM
RE: Pinebook Pro Initial Impressions - by beniro - 02-05-2020, 09:16 AM
RE: Pinebook Pro Initial Impressions - by fortran - 02-07-2020, 01:57 PM
RE: Pinebook Pro Initial Impressions - by neilman - 04-02-2020, 09:22 AM
RE: Pinebook Pro Initial Impressions - by 8-bit - 04-11-2020, 04:21 PM
RE: Pinebook Pro Initial Impressions - by Kochise - 04-13-2020, 12:56 AM
RE: Pinebook Pro Initial Impressions - by bcnaz - 04-13-2020, 11:45 PM
RE: Pinebook Pro Initial Impressions - by Wizzard - 04-12-2020, 05:11 AM
RE: Pinebook Pro Initial Impressions - by IoSer - 04-13-2020, 08:14 AM
RE: Pinebook Pro Initial Impressions - by Wizzard - 04-13-2020, 02:05 PM
RE: Pinebook Pro Initial Impressions - by IoSer - 04-13-2020, 02:21 PM
RE: Pinebook Pro Initial Impressions - by Lucy - 04-13-2020, 05:46 PM
RE: Pinebook Pro Initial Impressions - by Arwen - 04-16-2020, 06:19 PM
RE: Pinebook Pro Initial Impressions - by Tim-oh - 05-03-2020, 06:50 AM
RE: Pinebook Pro Initial Impressions - by poVoq - 06-05-2020, 08:27 AM
RE: Pinebook Pro Initial Impressions - by robt - 06-09-2020, 10:56 AM
RE: Pinebook Pro Initial Impressions - by pjsf - 06-09-2020, 04:24 PM
RE: Pinebook Pro Initial Impressions - by pjsf - 06-10-2020, 04:10 PM
RE: Pinebook Pro Initial Impressions - by nbxmike - 06-10-2020, 10:20 AM
RE: Pinebook Pro Initial Impressions - by timmes - 06-10-2020, 03:30 PM
RE: Pinebook Pro Initial Impressions - by robt - 06-15-2020, 04:03 AM
RE: Pinebook Pro Initial Impressions - by pciman - 06-15-2020, 05:56 PM
RE: Pinebook Pro Initial Impressions - by cefre00 - 06-16-2020, 05:31 AM
RE: Pinebook Pro Initial Impressions - by maba - 06-18-2020, 10:21 AM
RE: Pinebook Pro Initial Impressions - by Nobot - 06-18-2020, 06:19 PM
RE: Pinebook Pro Initial Impressions - by dnikkel - 06-20-2020, 08:57 PM
RE: Pinebook Pro Initial Impressions - by Upokupo - 06-24-2020, 06:10 PM
RE: Pinebook Pro Initial Impressions - by rohtua - 07-14-2020, 11:20 AM
RE: Pinebook Pro Initial Impressions - by bifo - 08-28-2020, 04:33 PM
RE: Pinebook Pro Initial Impressions - by bifo - 08-28-2020, 07:59 PM
RE: Pinebook Pro Initial Impressions - by PaulQ - 08-30-2020, 02:31 PM
RE: Pinebook Pro Initial Impressions - by PaulQ - 08-31-2020, 02:33 PM
RE: Pinebook Pro Initial Impressions - by brjaan - 10-27-2020, 09:00 PM
RE: Pinebook Pro Initial Impressions - by pFalken - 11-10-2020, 11:27 PM
RE: Pinebook Pro Initial Impressions - by Wizzard - 02-06-2021, 02:18 AM
RE: Pinebook Pro Initial Impressions - by vatin - 05-03-2021, 01:27 AM
RE: Pinebook Pro Initial Impressions - by ab1jx - 05-03-2021, 06:58 PM
RE: Pinebook Pro Initial Impressions - by mew2020 - 05-05-2021, 03:12 PM
RE: Pinebook Pro Initial Impressions - by ab1jx - 05-08-2021, 01:35 PM
RE: Pinebook Pro Initial Impressions - by doby - 05-11-2021, 07:36 AM
RE: Pinebook Pro Initial Impressions - by doby - 05-11-2021, 02:18 PM
RE: Pinebook Pro Initial Impressions - by KABA - 05-11-2021, 02:45 PM
RE: Pinebook Pro Initial Impressions - by KABA - 05-11-2021, 07:00 PM
RE: Pinebook Pro Initial Impressions - by KABA - 05-12-2021, 04:41 AM
RE: Pinebook Pro Initial Impressions - by ab1jx - 12-26-2021, 11:07 AM
RE: Pinebook Pro Initial Impressions - by Nuurd - 08-09-2022, 06:08 AM
RE: Pinebook Pro Initial Impressions - by bronson - 08-10-2022, 05:15 PM
RE: Pinebook Pro Initial Impressions - by jpalus - 08-11-2022, 05:10 PM
RE: Pinebook Pro Initial Impressions - by vandys - 01-08-2023, 07:06 PM
RE: Pinebook Pro Initial Impressions - by wdt - 01-09-2023, 01:37 PM
RE: Pinebook Pro Initial Impressions - by Tazdevl - 04-16-2024, 12:49 AM
RE: Pinebook Pro Initial Impressions - by KC9UDX - 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,366 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 449 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 340 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 326 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 262 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 721 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 807 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,746 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,354 12-15-2023, 02:11 PM
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 60,852 11-20-2023, 06:22 PM
