(11-08-2019, 12:06 PM)richfm Wrote:
(11-06-2019, 03:50 PM)rick1959 Wrote:
(11-06-2019, 02:02 PM)richfm Wrote:
(11-06-2019, 01:53 PM)rick1959 Wrote:
(11-06-2019, 01:41 PM)richfm Wrote: Rick, thanks for your reply.  I understand this is a community project but what if my wifi problem is a hardware problem?  I've tried everything everyone has suggested as you can see from my posts but it's almost impossible to use the PVP with any internet application. I've seen no one else here describing this problem so I'm assuming my PVP problem is unique. It's not that wifi is a weak point, it's practically unusable. I'm used to working with Linux on arm chromebooks so know something about the architecture. I'm flashing the original debian img file to the PVP now so we'll see.   However it's been a week since I received the device and have not been able to get it working satisfactorily yet.
You're welcome!
Clearly, there's a chance you could of got a klinker piece of hardware.
If it were me, I'd open a support request. From the pine64.org "start" page, along the top is tab listed as "Order Support". Click on it and submit a ticket (did I miss you've already done this?) for the problem. I, for one, will be interested to see how that plays out. If you're dissatisfied with that, perhaps a PM to an administrator, founder or someone like Luke might help it along....
There's absolutely no doubt that, despite best efforts, a hardware glitch could get through. You'll be helping not only yourself, but the rest of us see how the support function works here...
Does that help? :-)
Yes it does help, thanks. I've contacted tech support. I'll keep you posted.
Good Luck & Please do!
We'll all benefit from your experience!!! Standing by!! :-)
I found this in the PBP wiki and it seems to speed up wifi. "If having issues with wifi connectivity, try to disable power management in the 8723cs module options, adding rtw_power_mgnt=0 in /etc/modprobe.d/8723cs.conf
options 8723cs rtw_initmac=00:ba:ch:16:85:46 rtw_power_mgnt=0"
I didn't find a file named /etc/modprobe.d/8723cs.conf in the modprobe.d folder so I created one as root and copied the text "rtw_initmac=00:ba:ch:16:85:46 rtw_power_mgnt=0" and rebooted. Seems to help.
Thanks Rich!
I'll give it a try when next using the PBP and let you know my results. Hope others will do the same :-)
Pinebook Pro Initial Impressions - by kunger - 10-01-2019, 04:03 PM
RE: Pinebook Pro Initial Impressions - by Luke - 10-01-2019, 04:24 PM
RE: Pinebook Pro Initial Impressions - by danielt - 10-03-2019, 09:26 AM
RE: Pinebook Pro Initial Impressions - by bcnaz - 11-08-2019, 09:06 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 11-10-2019, 12:59 PM
RE: Pinebook Pro Initial Impressions - by odinson - 10-01-2019, 05:17 PM
RE: Pinebook Pro Initial Impressions - by Luke - 10-01-2019, 05:49 PM
RE: Pinebook Pro Initial Impressions - by jabo - 10-01-2019, 06:28 PM
RE: Pinebook Pro Initial Impressions - by Wizzard - 10-02-2019, 05:51 AM
RE: Pinebook Pro Initial Impressions - by kunger - 10-02-2019, 07:00 AM
RE: Pinebook Pro Initial Impressions - by Wizzard - 10-02-2019, 07:09 AM
RE: Pinebook Pro Initial Impressions - by neilman - 10-02-2019, 07:09 AM
RE: Pinebook Pro Initial Impressions - by PakoSt - 10-02-2019, 07:52 AM
RE: Pinebook Pro Initial Impressions - by kunger - 10-02-2019, 07:22 AM
RE: Pinebook Pro Initial Impressions - by jabo - 10-02-2019, 07:47 AM
RE: Pinebook Pro Initial Impressions - by neilman - 10-02-2019, 07:57 AM
RE: Pinebook Pro Initial Impressions - by Luke - 10-02-2019, 08:38 AM
RE: Pinebook Pro Initial Impressions - by neilman - 10-02-2019, 09:08 AM
RE: Pinebook Pro Initial Impressions - by Luke - 10-02-2019, 09:24 AM
RE: Pinebook Pro Initial Impressions - by kaylios - 10-02-2019, 02:27 PM
RE: Pinebook Pro Initial Impressions - by neilman - 10-02-2019, 09:41 AM
RE: Pinebook Pro Initial Impressions - by Luke - 10-02-2019, 09:58 AM
RE: Pinebook Pro Initial Impressions - by neilman - 10-02-2019, 03:23 PM
RE: Pinebook Pro Initial Impressions - by kaylios - 10-03-2019, 02:26 AM
RE: Pinebook Pro Initial Impressions - by Omli - 10-02-2019, 04:07 PM
RE: Pinebook Pro Initial Impressions - by venix1 - 10-02-2019, 10:26 PM
RE: Pinebook Pro Initial Impressions - by zaius - 10-03-2019, 12:42 PM
RE: Pinebook Pro Initial Impressions - by kunger - 10-02-2019, 05:56 PM
RE: Pinebook Pro Initial Impressions - by neilman - 10-03-2019, 06:36 AM
RE: Pinebook Pro Initial Impressions - by PakoSt - 10-03-2019, 07:08 AM
RE: Pinebook Pro Initial Impressions - by kaylios - 10-03-2019, 07:30 AM
RE: Pinebook Pro Initial Impressions - by neilman - 10-03-2019, 07:53 AM
RE: Pinebook Pro Initial Impressions - by danielt - 10-03-2019, 03:19 PM
RE: Pinebook Pro Initial Impressions - by Luke - 10-03-2019, 03:21 PM
RE: Pinebook Pro Initial Impressions - by Luke - 10-03-2019, 08:23 AM
RE: Pinebook Pro Initial Impressions - by Omli - 10-04-2019, 06:22 PM
RE: Pinebook Pro Initial Impressions - by neilman - 10-03-2019, 09:33 AM
RE: Pinebook Pro Initial Impressions - by Luke - 10-03-2019, 09:39 AM
RE: Pinebook Pro Initial Impressions - by neilman - 10-03-2019, 09:45 AM
RE: Pinebook Pro Initial Impressions - by Luke - 10-03-2019, 10:07 AM
RE: Pinebook Pro Initial Impressions - by neilman - 10-03-2019, 11:01 AM
RE: Pinebook Pro Initial Impressions - by kunger - 10-03-2019, 01:34 PM
RE: Pinebook Pro Initial Impressions - by danielt - 10-03-2019, 10:14 AM
RE: Pinebook Pro Initial Impressions - by Luke - 10-03-2019, 01:38 PM
RE: Pinebook Pro Initial Impressions - by neilman - 10-03-2019, 01:58 PM
RE: Pinebook Pro Initial Impressions - by Luke - 10-03-2019, 02:05 PM
RE: Pinebook Pro Initial Impressions - by neilman - 10-03-2019, 05:08 PM
RE: Pinebook Pro Initial Impressions - by Arwen - 10-03-2019, 05:28 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 10-03-2019, 08:49 PM
RE: Pinebook Pro Initial Impressions - by Luke - 10-03-2019, 06:04 PM
RE: Pinebook Pro Initial Impressions - by zaius - 10-04-2019, 12:51 PM
RE: Pinebook Pro Initial Impressions - by tsago - 10-05-2019, 03:10 AM
RE: Pinebook Pro Initial Impressions - by PakoSt - 10-08-2019, 05:22 AM
RE: Pinebook Pro Initial Impressions - by zaius - 10-19-2019, 01:03 PM
RE: Pinebook Pro Initial Impressions - by Luke - 10-19-2019, 04:41 PM
RE: Pinebook Pro Initial Impressions - by zaius - 10-19-2019, 05:34 PM
RE: Pinebook Pro Initial Impressions - by Luke - 10-19-2019, 06:19 PM
RE: Pinebook Pro Initial Impressions - by zaius - 10-22-2019, 04:54 PM
RE: Pinebook Pro Initial Impressions - by zaius - 10-23-2019, 06:10 AM
RE: Pinebook Pro Initial Impressions - by Luke - 10-23-2019, 05:57 PM
RE: Pinebook Pro Initial Impressions - by Wizzard - 10-24-2019, 12:39 AM
RE: Pinebook Pro Initial Impressions - by tsago - 10-24-2019, 12:03 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 10-27-2019, 06:14 PM
RE: Pinebook Pro Initial Impressions - by fire219 - 10-26-2019, 10:33 AM
RE: Pinebook Pro Initial Impressions - by bcnaz - 10-28-2019, 11:49 AM
RE: Pinebook Pro Initial Impressions - by Wizzard - 10-31-2019, 03:13 AM
RE: Pinebook Pro Initial Impressions - by Arwen - 10-31-2019, 04:50 PM
RE: Pinebook Pro Initial Impressions - by hmuller - 10-31-2019, 09:20 PM
RE: Pinebook Pro Initial Impressions - by Wizzard - 11-01-2019, 06:19 AM
RE: Pinebook Pro Initial Impressions - by richfm - 11-01-2019, 07:56 AM
RE: Pinebook Pro Initial Impressions - by noisy - 11-01-2019, 08:03 AM
RE: Pinebook Pro Initial Impressions - by neilman - 11-01-2019, 08:35 AM
RE: Pinebook Pro Initial Impressions - by richfm - 11-01-2019, 09:04 AM
RE: Pinebook Pro Initial Impressions - by neilman - 11-01-2019, 09:22 AM
RE: Pinebook Pro Initial Impressions - by richfm - 11-01-2019, 11:18 AM
Pinebook Pro Initial Impressions - by Wizzard - 11-01-2019, 08:03 AM
RE: Pinebook Pro Initial Impressions - by bcnaz - 11-01-2019, 09:48 AM
RE: Pinebook Pro Initial Impressions - by zaius - 11-01-2019, 04:26 PM
RE: Pinebook Pro Initial Impressions - by Luke - 11-01-2019, 05:33 PM
RE: Pinebook Pro Initial Impressions - by Luke - 11-01-2019, 06:26 PM
RE: Pinebook Pro Initial Impressions - by mspohr - 11-01-2019, 07:23 PM
RE: Pinebook Pro Initial Impressions - by neilman - 11-01-2019, 07:37 PM
RE: Pinebook Pro Initial Impressions - by sundog - 11-01-2019, 09:42 PM
RE: Pinebook Pro Initial Impressions - by hmuller - 11-02-2019, 05:08 AM
RE: Pinebook Pro Initial Impressions - by richfm - 11-02-2019, 08:42 AM
RE: Pinebook Pro Initial Impressions - by richfm - 11-05-2019, 08:49 AM
RE: Pinebook Pro Initial Impressions - by richfm - 11-05-2019, 09:47 PM
RE: Pinebook Pro Initial Impressions - by richfm - 11-06-2019, 09:20 AM
RE: Pinebook Pro Initial Impressions - by richfm - 11-06-2019, 01:41 PM
RE: Pinebook Pro Initial Impressions - by richfm - 11-06-2019, 02:02 PM
RE: Pinebook Pro Initial Impressions - by richfm - 11-08-2019, 12:06 PM
RE: Pinebook Pro Initial Impressions - by User 6582 - 11-08-2019, 01:01 PM
RE: Pinebook Pro Initial Impressions - by zaius - 11-02-2019, 12:49 PM
RE: Pinebook Pro Initial Impressions - by mattjb - 11-02-2019, 06:32 AM
RE: Pinebook Pro Initial Impressions - by mattjb - 11-02-2019, 02:34 PM
RE: Pinebook Pro Initial Impressions - by mspohr - 11-02-2019, 09:12 AM
RE: Pinebook Pro Initial Impressions - by embhorn - 11-02-2019, 12:32 PM
RE: Pinebook Pro Initial Impressions - by JayM - 11-02-2019, 10:15 AM
RE: Pinebook Pro Initial Impressions - by mspohr - 11-03-2019, 11:10 AM
I am impressed - by Kicou - 11-04-2019, 06:33 AM
RE: Pinebook Pro Initial Impressions - by m80 - 11-04-2019, 09:59 AM
RE: Pinebook Pro Initial Impressions - by m80 - 11-04-2019, 02:50 PM
RE: Pinebook Pro Initial Impressions - by richfm - 11-04-2019, 03:50 PM
RE: Pinebook Pro Initial Impressions - by nearsky - 11-04-2019, 12:25 PM
RE: Pinebook Pro Initial Impressions - by richfm - 11-05-2019, 09:51 AM
RE: Pinebook Pro Initial Impressions - by zaius - 11-05-2019, 11:54 AM
RE: Pinebook Pro Initial Impressions - by richfm - 11-05-2019, 02:04 PM
RE: Pinebook Pro Initial Impressions - by zaius - 11-06-2019, 07:09 AM
RE: Pinebook Pro Initial Impressions - by Nappael - 11-05-2019, 05:04 PM
RE: Pinebook Pro Initial Impressions - by stanski - 11-06-2019, 12:02 PM
RE: Pinebook Pro Initial Impressions - by Depau - 11-07-2019, 06:48 AM
RE: Pinebook Pro Initial Impressions - by zaius - 11-07-2019, 07:44 AM
RE: Pinebook Pro Initial Impressions - by Depau - 11-07-2019, 08:07 AM
RE: Pinebook Pro Initial Impressions - by Depau - 11-07-2019, 11:46 AM
RE: Pinebook Pro Initial Impressions - by bcnaz - 11-08-2019, 09:19 PM
RE: Pinebook Pro Initial Impressions - by tgrauss - 11-09-2019, 03:08 AM
RE: Pinebook Pro Initial Impressions - by MC68060 - 11-09-2019, 02:15 PM
RE: Pinebook Pro Initial Impressions - by Arwen - 11-10-2019, 03:01 PM
RE: Pinebook Pro Initial Impressions - by odinson - 11-11-2019, 11:50 PM
RE: Pinebook Pro Initial Impressions - by pnts-se - 11-12-2019, 05:39 AM
RE: Pinebook Pro Initial Impressions - by r59vde - 11-12-2019, 03:35 PM
RE: Pinebook Pro Initial Impressions - by Nappael - 11-15-2019, 06:07 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 11-16-2019, 01:32 PM
RE: Pinebook Pro Initial Impressions - by Nappael - 11-18-2019, 05:07 AM
RE: Pinebook Pro Initial Impressions - by enip - 11-16-2019, 09:22 AM
RE: Pinebook Pro Initial Impressions - by SuperUJ - 11-16-2019, 05:22 PM
RE: Pinebook Pro Initial Impressions - by jiyong - 11-18-2019, 03:30 PM
RE: Pinebook Pro Initial Impressions - by jiyong - 11-19-2019, 03:39 PM
RE: Pinebook Pro Initial Impressions - by Kochise - 11-19-2019, 02:57 PM
RE: Pinebook Pro Initial Impressions - by Luke - 11-23-2019, 06:22 PM
RE: Pinebook Pro Initial Impressions - by Luke - 11-29-2019, 01:00 PM
RE: Pinebook Pro Initial Impressions - by Luke - 11-29-2019, 02:55 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 11-26-2019, 12:56 PM
video of wifi performance on PBP - by richfm - 11-27-2019, 12:19 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 11-27-2019, 12:33 PM
RE: Pinebook Pro Initial Impressions - by richfm - 11-27-2019, 04:30 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 11-27-2019, 08:44 PM
RE: Pinebook Pro Initial Impressions - by richfm - 11-28-2019, 08:26 AM
RE: Pinebook Pro Initial Impressions - by bcnaz - 11-28-2019, 10:19 AM
RE: Pinebook Pro Initial Impressions - by richfm - 11-28-2019, 11:05 AM
RE: Pinebook Pro Initial Impressions - by Arwen - 11-28-2019, 03:19 PM
RE: Pinebook Pro Initial Impressions - by richfm - 11-30-2019, 09:11 AM
RE: Pinebook Pro Initial Impressions - by ndp - 11-28-2019, 09:45 AM
RE: Pinebook Pro Initial Impressions - by Arwen - 11-30-2019, 10:09 AM
RE: Pinebook Pro Initial Impressions - by richfm - 11-30-2019, 03:30 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 11-30-2019, 04:14 PM
RE: Pinebook Pro Initial Impressions - by richfm - 12-01-2019, 08:18 AM
RE: Pinebook Pro Initial Impressions - by bcnaz - 12-03-2019, 02:38 PM
RE: Pinebook Pro Initial Impressions - by Kochise - 12-04-2019, 03:38 AM
RE: Pinebook Pro Initial Impressions - by richfm - 12-04-2019, 09:12 AM
RE: Pinebook Pro Initial Impressions - by Kochise - 12-04-2019, 11:10 AM
RE: Pinebook Pro Initial Impressions - by gristle - 12-06-2019, 03:06 PM
RE: Pinebook Pro Initial Impressions - by neilman - 12-06-2019, 03:25 PM
RE: Pinebook Pro Initial Impressions - by gristle - 12-06-2019, 04:09 PM
RE: Pinebook Pro Initial Impressions - by neilman - 12-06-2019, 04:43 PM
RE: Pinebook Pro Initial Impressions - by Arwen - 12-06-2019, 05:01 PM
RE: Pinebook Pro Initial Impressions - by Arwen - 12-07-2019, 04:50 PM
RE: Pinebook Pro Initial Impressions - by MrRobot - 12-09-2019, 02:29 PM
RE: Pinebook Pro Initial Impressions - by z4v4l - 12-19-2019, 02:05 PM
RE: Pinebook Pro Initial Impressions - by Kochise - 12-19-2019, 01:40 PM
RE: Pinebook Pro Initial Impressions - by Arwen - 12-20-2019, 08:31 PM
RE: Pinebook Pro Initial Impressions - by abdel - 12-21-2019, 10:17 AM
Pinebook Pro Initial Impressions - by balder - 12-21-2019, 11:09 AM
RE: Pinebook Pro Initial Impressions - by abdel - 12-21-2019, 11:34 AM
RE: Pinebook Pro Initial Impressions - by 8jef - 12-23-2019, 01:25 PM
RE: Pinebook Pro Initial Impressions - by 8jef - 12-23-2019, 10:02 PM
RE: Pinebook Pro Initial Impressions - by Twix166 - 12-30-2019, 04:28 AM
RE: Pinebook Pro Initial Impressions - by Twix166 - 12-31-2019, 12:22 PM
RE: Pinebook Pro Initial Impressions - by Twix166 - 01-03-2020, 12:53 PM
RE: Pinebook Pro Initial Impressions - by giav - 12-30-2019, 08:39 AM
RE: Pinebook Pro Initial Impressions - by neilman - 12-30-2019, 09:08 AM
RE: Pinebook Pro Initial Impressions - by bcnaz - 12-31-2019, 02:43 AM
RE: Pinebook Pro Initial Impressions - by whinsch - 01-03-2020, 09:10 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 01-03-2020, 09:15 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 01-07-2020, 05:34 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 01-09-2020, 09:15 AM
RE: Pinebook Pro Initial Impressions - by bcnaz - 01-09-2020, 04:06 PM
RE: Pinebook Pro Initial Impressions - by noahvg - 01-09-2020, 02:24 PM
RE: Pinebook Pro Initial Impressions - by Luke - 01-09-2020, 02:49 PM
RE: Pinebook Pro Initial Impressions - by Arwen - 01-10-2020, 06:03 AM
RE: Pinebook Pro Initial Impressions - by rossk - 01-10-2020, 03:02 PM
RE: Pinebook Pro Initial Impressions - by gillham - 01-12-2020, 01:33 AM
RE: Pinebook Pro Initial Impressions - by amp - 01-13-2020, 02:28 AM
RE: Pinebook Pro Initial Impressions - by rleasle - 01-18-2020, 08:49 AM
RE: Pinebook Pro Initial Impressions - by Wizzard - 01-12-2020, 01:46 PM
RE: Pinebook Pro Initial Impressions - by fpex73 - 01-13-2020, 06:22 AM
RE: Pinebook Pro Initial Impressions - by Luke - 01-13-2020, 06:38 AM
RE: Pinebook Pro Initial Impressions - by fpex73 - 01-13-2020, 06:46 AM
RE: Pinebook Pro Initial Impressions - by Luke - 01-13-2020, 08:00 AM
RE: Pinebook Pro Initial Impressions - by fpex73 - 01-13-2020, 09:20 AM
RE: Pinebook Pro Initial Impressions - by Arwen - 01-13-2020, 05:57 PM
RE: Pinebook Pro Initial Impressions - by fpex73 - 01-14-2020, 12:14 AM
RE: Pinebook Pro Initial Impressions - by Arwen - 01-14-2020, 07:57 AM
RE: Pinebook Pro Initial Impressions - by ab1jx - 01-14-2020, 10:58 AM
Pinebook Pro Initial Impressions - by jsfrederick - 01-14-2020, 07:52 PM
RE: Pinebook Pro Initial Impressions - by amooke - 01-14-2020, 08:24 PM
RE: Pinebook Pro Initial Impressions - by Arwen - 01-14-2020, 08:59 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 01-14-2020, 11:02 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 01-15-2020, 01:36 AM
RE: Pinebook Pro Initial Impressions - by bcnaz - 01-15-2020, 03:41 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 01-15-2020, 04:12 PM
RE: Pinebook Pro Initial Impressions - by 8jef - 01-15-2020, 07:54 PM
RE: Pinebook Pro Initial Impressions - by fortran - 01-15-2020, 08:32 PM
RE: Pinebook Pro Initial Impressions - by 8jef - 01-15-2020, 09:17 PM
RE: Pinebook Pro Initial Impressions - by fortran - 01-17-2020, 01:17 PM
RE: Pinebook Pro Initial Impressions - by fortran - 01-18-2020, 12:49 PM
RE: Pinebook Pro Initial Impressions - by Kochise - 01-18-2020, 01:32 PM
RE: Pinebook Pro Initial Impressions - by bcnaz - 01-18-2020, 02:36 PM
RE: Pinebook Pro Initial Impressions - by rossk - 01-21-2020, 07:52 AM
RE: Pinebook Pro Initial Impressions - by Syg - 01-21-2020, 10:34 AM
RE: Pinebook Pro Initial Impressions - by avill - 01-21-2020, 07:46 PM
RE: Pinebook Pro Initial Impressions - by Luke - 01-23-2020, 08:16 AM
RE: Pinebook Pro Initial Impressions - by wove - 01-31-2020, 08:21 AM
RE: Pinebook Pro Initial Impressions - by beniro - 02-05-2020, 09:16 AM
RE: Pinebook Pro Initial Impressions - by fortran - 02-07-2020, 01:57 PM
RE: Pinebook Pro Initial Impressions - by neilman - 04-02-2020, 09:22 AM
RE: Pinebook Pro Initial Impressions - by 8-bit - 04-11-2020, 04:21 PM
RE: Pinebook Pro Initial Impressions - by Kochise - 04-13-2020, 12:56 AM
RE: Pinebook Pro Initial Impressions - by bcnaz - 04-13-2020, 11:45 PM
RE: Pinebook Pro Initial Impressions - by Wizzard - 04-12-2020, 05:11 AM
RE: Pinebook Pro Initial Impressions - by IoSer - 04-13-2020, 08:14 AM
RE: Pinebook Pro Initial Impressions - by Wizzard - 04-13-2020, 02:05 PM
RE: Pinebook Pro Initial Impressions - by IoSer - 04-13-2020, 02:21 PM
RE: Pinebook Pro Initial Impressions - by Lucy - 04-13-2020, 05:46 PM
RE: Pinebook Pro Initial Impressions - by Arwen - 04-16-2020, 06:19 PM
RE: Pinebook Pro Initial Impressions - by Tim-oh - 05-03-2020, 06:50 AM
RE: Pinebook Pro Initial Impressions - by poVoq - 06-05-2020, 08:27 AM
RE: Pinebook Pro Initial Impressions - by robt - 06-09-2020, 10:56 AM
RE: Pinebook Pro Initial Impressions - by pjsf - 06-09-2020, 04:24 PM
RE: Pinebook Pro Initial Impressions - by pjsf - 06-10-2020, 04:10 PM
RE: Pinebook Pro Initial Impressions - by nbxmike - 06-10-2020, 10:20 AM
RE: Pinebook Pro Initial Impressions - by timmes - 06-10-2020, 03:30 PM
RE: Pinebook Pro Initial Impressions - by robt - 06-15-2020, 04:03 AM
RE: Pinebook Pro Initial Impressions - by pciman - 06-15-2020, 05:56 PM
RE: Pinebook Pro Initial Impressions - by cefre00 - 06-16-2020, 05:31 AM
RE: Pinebook Pro Initial Impressions - by maba - 06-18-2020, 10:21 AM
RE: Pinebook Pro Initial Impressions - by Nobot - 06-18-2020, 06:19 PM
RE: Pinebook Pro Initial Impressions - by dnikkel - 06-20-2020, 08:57 PM
RE: Pinebook Pro Initial Impressions - by Upokupo - 06-24-2020, 06:10 PM
RE: Pinebook Pro Initial Impressions - by rohtua - 07-14-2020, 11:20 AM
RE: Pinebook Pro Initial Impressions - by bifo - 08-28-2020, 04:33 PM
RE: Pinebook Pro Initial Impressions - by bifo - 08-28-2020, 07:59 PM
RE: Pinebook Pro Initial Impressions - by PaulQ - 08-30-2020, 02:31 PM
RE: Pinebook Pro Initial Impressions - by PaulQ - 08-31-2020, 02:33 PM
RE: Pinebook Pro Initial Impressions - by brjaan - 10-27-2020, 09:00 PM
RE: Pinebook Pro Initial Impressions - by pFalken - 11-10-2020, 11:27 PM
RE: Pinebook Pro Initial Impressions - by Wizzard - 02-06-2021, 02:18 AM
RE: Pinebook Pro Initial Impressions - by vatin - 05-03-2021, 01:27 AM
RE: Pinebook Pro Initial Impressions - by ab1jx - 05-03-2021, 06:58 PM
RE: Pinebook Pro Initial Impressions - by mew2020 - 05-05-2021, 03:12 PM
RE: Pinebook Pro Initial Impressions - by ab1jx - 05-08-2021, 01:35 PM
RE: Pinebook Pro Initial Impressions - by doby - 05-11-2021, 07:36 AM
RE: Pinebook Pro Initial Impressions - by doby - 05-11-2021, 02:18 PM
RE: Pinebook Pro Initial Impressions - by KABA - 05-11-2021, 02:45 PM
RE: Pinebook Pro Initial Impressions - by KABA - 05-11-2021, 07:00 PM
RE: Pinebook Pro Initial Impressions - by KABA - 05-12-2021, 04:41 AM
RE: Pinebook Pro Initial Impressions - by ab1jx - 12-26-2021, 11:07 AM
RE: Pinebook Pro Initial Impressions - by Nuurd - 08-09-2022, 06:08 AM
RE: Pinebook Pro Initial Impressions - by bronson - 08-10-2022, 05:15 PM
RE: Pinebook Pro Initial Impressions - by jpalus - 08-11-2022, 05:10 PM
RE: Pinebook Pro Initial Impressions - by vandys - 01-08-2023, 07:06 PM
RE: Pinebook Pro Initial Impressions - by wdt - 01-09-2023, 01:37 PM
RE: Pinebook Pro Initial Impressions - by Tazdevl - 04-16-2024, 12:49 AM
RE: Pinebook Pro Initial Impressions - by KC9UDX - 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,377 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 462 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 344 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 332 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 266 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 743 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 818 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,782 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,391 12-15-2023, 02:11 PM
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 60,987 11-20-2023, 06:22 PM
