Pinebook Pro Audio Codecs
(09-05-2019, 09:37 PM)evantaylor Wrote:
(09-05-2019, 10:57 AM)CryptoRick Wrote: Something they don't really cover, or I haven't been able to find where it is, is what audio codecs will this work with? Aptx hd, LDAC, AAC or SBC? hoping for Aptx hd
It's likely using the same wifi/bluetooth module as the RockPro64 adapter:
https://store.pine64.org/?product=rockpr...4-1-module
It seems to use a Broadcom BCM4359 wifi/bluetooth module.
You may be able to see what codecs are supported in hardware, but I would not assume a Qualcomm proprietary audio codec is likely to be supported in an older broadcom chip.
The Pinebook Pro uses a Ampack AP6255 module, which internally is effectively a Broadcom BCM43455. So, you're actually pretty close except that the 43455 is 1x1 WiFi. But that does not change the Bluetooth capabilities in any way.
To the best I can tell, most of those Bluetooth audio codecs are dependent solely on the software (with maybe the exception of AptX), so it will probably depend on what distro you have installed on your PBP.
Pinebook Pro Audio Codecs - by CryptoRick - 09-05-2019, 10:57 AM
RE: Pinebook Pro Audio Codecs - by evantaylor - 09-05-2019, 09:37 PM
RE: Pinebook Pro Audio Codecs - by fire219 - 09-06-2019, 08:56 AM
RE: Pinebook Pro Audio Codecs - by CryptoRick - 09-06-2019, 09:11 AM
  Pinebook Pro Initial Impressions kunger 443 597,878 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,371 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 456 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 342 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 329 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 264 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 739 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 817 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,768 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,374 12-15-2023, 02:11 PM
