Forcing u-boot to detect USB3 storage
Okay!
Changing it to use /dev/sda7 to match the same ext4 root filesystem worked like a champ. Now the filesystem looks like:
rock64@rock64:~$ df
Filesystem     1K-blocks    Used Available Use% Mounted on
udev             2038168       0   2038168   0% /dev
tmpfs             408344     436    407908   1% /run
/dev/sda7      230596488 1278064 219910820   1% /
tmpfs            2041720       0   2041720   0% /dev/shm
tmpfs               5120       4      5116   1% /run/lock
tmpfs            2041720       0   2041720   0% /sys/fs/cgroup
/dev/mmcblk1p6    114446      10    114436   1% /boot/efi
tmpfs             408344       0    408344   0% /run/user/1000
the /boot is off of the microSD card (which is fine to leave the img files there) and the rest of the setup is off of /dev/sda7. I could probably tweak it so that boot is off of /dev/sda6 but honestly that doesn't matter anymore. I just need to remember if I rebuild anything with the boot image, etc., that I make sure to update the proper img files.
For all intents and purposes, the microSD isn't being hammered now for I/O so this should be great.
Thanks!
(04-02-2019, 09:11 PM)t4_4t Wrote: > sda7:               linux-root
> mmcblk1p7:    linux-root
That is because the labels are duplicated.
If you change the label of sda7, it works properly.
Yep. I think I'll take the extra step and do it by UUID like you suggested in case I want to hang a backup drive off one of the USB 2.0 ports.
Thanks for your help!
RE: Forcing u-boot to detect USB3 storage - by SirRyanTheGeek - 04-02-2019, 09:19 PM
  Rock64 won't boot dstallmo 0 370 12-27-2023, 10:34 AM
Last Post: dstallmo
  arch rock64 does not boot nemnob 0 627 07-09-2023, 03:28 AM
Last Post: nemnob
  Disabling last mount time check on boot acwest 0 657 03-03-2023, 09:24 PM
Last Post: acwest
  Swap/Upgrade Storage Device? r00t3d 0 710 08-17-2022, 06:11 AM
Last Post: r00t3d
  USB3.0 Issues at DietPi(Armbian) #22.02.1 t4_4t 3 2,425 08-15-2022, 06:58 PM
Last Post: TRS-80
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 7,895 06-30-2022, 06:28 PM
Last Post: rookie_267
  my rock64 can't boot rookie_267 0 1,074 06-27-2022, 06:52 PM
  Setting a MAC on Rock64 U-Boot kiriakos 2 3,625 03-23-2021, 04:51 AM
Last Post: kiriakos
  Boot from USB 3.0 with hub Turbo 0 2,132 12-20-2020, 02:24 PM
Last Post: Turbo
  Unable to boot armbian fchazal 2 3,917 05-19-2020, 06:43 PM
Last Post: Rocklobster
