Forcing u-boot to detect USB3 storage
> sda7:               linux-root
> mmcblk1p7:    linux-root
That is because the labels are duplicated.
If you change the label of sda7, it works properly.
Eg) sda7: linux-root-sd
And then change the following.
root=LABEL=linux-root  ->  root=LABEL=linux-root-sd
Another way is to change the root=/dev/sda7.
However, if you connect multiple "usb-device" in this method, the device file name may change.
Therefore, It is better to specify by LABEL or UUID or PARTUUID.
In this way,
you can reliably mount the specified device regardless of the increase or decrease in the number of "usb-device" connections.
RE: Forcing u-boot to detect USB3 storage - by t4_4t - 04-02-2019, 09:11 PM
  Rock64 won't boot dstallmo 0 370 12-27-2023, 10:34 AM
Last Post: dstallmo
  arch rock64 does not boot nemnob 0 629 07-09-2023, 03:28 AM
Last Post: nemnob
  Disabling last mount time check on boot acwest 0 661 03-03-2023, 09:24 PM
Last Post: acwest
  Swap/Upgrade Storage Device? r00t3d 0 713 08-17-2022, 06:11 AM
Last Post: r00t3d
  USB3.0 Issues at DietPi(Armbian) #22.02.1 t4_4t 3 2,440 08-15-2022, 06:58 PM
Last Post: TRS-80
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 7,905 06-30-2022, 06:28 PM
Last Post: rookie_267
  my rock64 can't boot rookie_267 0 1,074 06-27-2022, 06:52 PM
  Setting a MAC on Rock64 U-Boot kiriakos 2 3,628 03-23-2021, 04:51 AM
Last Post: kiriakos
  Boot from USB 3.0 with hub Turbo 0 2,138 12-20-2020, 02:24 PM
Last Post: Turbo
  Unable to boot armbian fchazal 2 3,919 05-19-2020, 06:43 PM
Last Post: Rocklobster
