Wifi problem
(11-28-2018, 06:26 AM)evilbunny Wrote:
(11-28-2018, 05:51 AM)Nether494 Wrote: I have a error again
root@rock64:/usr/src/rtl8811au# make
make ARCH=arm64 -j4 CROSS_COMPILE=/home/android_sdk/Rockchip/Rk3188/prebuilts/gcc/linux-x86/arm/arm-eabi-4.6/bin/arm-eabi- -C /home/android_sdk/Rockchip/Rk3188/kernel M=/usr/src/rtl8811au  modules
make[1]: *** /home/android_sdk/Rockchip/Rk3188/kernel: No such file or directory.  Stop.
Makefile:1554: recipe for target 'modules' failed
make: *** [modules] Error 2
This is my makefile -> https://pastebin.com/X4YSEChB
Best regards
Are you trying to build this on something other than a rock64/rockpro64?
No, I have a rock64 4GB with this release on my eMMC 16 go -> stretch-openmediavault-rock64-0.7.11-1075-arm64.img.xz
Is there something that is not clear? Do you think I have to use this release? ->stretch-openmediavault-rock64-0.7.11-1075-armhf.img.xz
Best regards
EDIT
Same problem with this release -> stretch-openmediavault-rock64-0.7.11-1075-armhf.img.xz
sudo lshw
To prove that I have a rock64
root@rock64:/# sudo lshw
rock64
   description: ARMv8 Processor rev 4 (v8l)
   product: Pine64 Rock64
   serial: e4f5xxxxxxxxx
   width: 32 bits
   capabilities: smp cp15_barrier setend swp
 *-core
      description: Motherboard
      physical id: 0
    *-cpu:0
         description: CPU
         product: cpu
         physical id: 0
         bus info: cpu@0
         capacity: 1296MHz
         capabilities: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt lpae evtstrm aes pmull sha1 sha2 crc32 cpufreq
    *-cpu:1
         description: CPU
         product: cpu
         physical id: 1
         bus info: cpu@1
         capacity: 1296MHz
    *-cpu:2
         description: CPU
         product: cpu
         physical id: 2
         bus info: cpu@2
         capacity: 1296MHz
    *-cpu:3
         description: CPU
         product: cpu
         physical id: 3
         bus info: cpu@3
         capacity: 1296MHz
    *-memory
         description: System memory
         physical id: 4
 *-usbhost:0
      product: xHCI Host Controller
      vendor: Linux 4.4.154-1124-rockchip-ayufan-ged3ce4d15ec1 xhci-hcd
      physical id: 2
      bus info: usb@5
      logical name: usb5
      version: 4.04
      capabilities: usb-3.00
      configuration: driver=hub slots=1 speed=5000Mbit/s
 *-usbhost:1
      physical id: 3
      bus info: usb@4
      logical name: usb4
      version: 4.04
      capabilities: usb-2.00
      configuration: driver=hub slots=1 speed=480Mbit/s
 *-usbhost:2
      product: Generic Platform OHCI controller
      vendor: Linux 4.4.154-1124-rockchip-ayufan-ged3ce4d15ec1 ohci_hcd
      physical id: 4
      bus info: usb@3
      logical name: usb3
      version: 4.04
      capabilities: usb-1.10
      configuration: driver=hub slots=1 speed=12Mbit/s
 *-usbhost:3
      product: EHCI Host Controller
      vendor: Linux 4.4.154-1124-rockchip-ayufan-ged3ce4d15ec1 ehci_hcd
      physical id: 5
      bus info: usb@2
      logical name: usb2
      version: 4.04
    *-usb UNCLAIMED
         description: Generic USB device
         product: 802.11ac WLAN Adapter
         vendor: Realtek
         physical id: 1
         bus info: usb@2:1
         version: 2.00
         serial: 00e04c000001
         capabilities: usb-2.10
         configuration: maxpower=500mA speed=480Mbit/s
 *-usbhost:4
      product: DWC OTG Controller
      vendor: Linux 4.4.154-1124-rockchip-ayufan-ged3ce4d15ec1 dwc2_hsotg
      physical id: 1
      bus info: usb@1
      logical name: usb1
      version: 4.04
 *-network
      description: Ethernet interface
      physical id: 6
      logical name: eth0
      serial: c2:5a:xx:xx:xx:xx
      capacity: 1Gbit/s
      capabilities: ethernet physical tp aui bnc mii fibre 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
      configuration: autonegotiation=on broadcast=yes driver=st_gmac driverversion=March_2013 duplex=full ip=192.168.0.21 link=yes multicast=yes port=MII speed=100Mbit/s
Wifi problem - by Nether494 - 11-27-2018, 08:36 AM
RE: Wifi problem - by Nether494 - 11-27-2018, 11:59 AM
RE: Wifi problem - by evilbunny - 11-27-2018, 03:42 PM
RE: Wifi problem - by Nether494 - 11-27-2018, 06:21 PM
RE: Wifi problem - by evilbunny - 11-27-2018, 07:33 PM
RE: Wifi problem - by Nether494 - 11-28-2018, 04:28 AM
RE: Wifi problem - by evilbunny - 11-28-2018, 04:43 AM
RE: Wifi problem - by Nether494 - 11-28-2018, 05:07 AM
RE: Wifi problem - by evilbunny - 11-28-2018, 05:37 AM
RE: Wifi problem - by Nether494 - 11-28-2018, 05:51 AM
RE: Wifi problem - by evilbunny - 11-28-2018, 06:26 AM
RE: Wifi problem - by Nether494 - 11-28-2018, 06:32 AM
RE: Wifi problem - by mcerveny - 11-28-2018, 09:48 AM
RE: Wifi problem - by Nether494 - 11-28-2018, 01:48 PM
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,421 10-12-2023, 05:14 PM
Last Post: tpaul
  External hard drive problem k8Va 17 22,621 03-09-2021, 02:31 PM
Last Post: calinb
  Arch Linux Arm - external RTC problem max 1 2,991 08-17-2020, 10:35 AM
Last Post: max
  Read-only problem mikedhoore 5 6,895 07-14-2020, 11:41 AM
Last Post: zein
Question bluetooth rock64 problem deta 3 5,072 05-06-2020, 11:29 PM
Last Post: deta
  Fedora 31 crosscompilation fdt problem mimics debian 888789 kf5zmi 2 4,173 01-20-2020, 12:25 PM
Last Post: kf5zmi
  Ayufan Debian Stretch Openmediavault 4 5G Wifi Not Connecting Poincare 0 2,273 03-26-2019, 07:28 PM
Last Post: Poincare
  ROCK64 Kernel compilation problem cao 0 2,482 01-21-2019, 01:21 AM
Last Post: cao
  Can't connect to wifi on a Rock64 SuperSaiyanCaleb 2 4,194 12-18-2018, 11:51 PM
Last Post: SuperSaiyanCaleb
  8812au wifi driver OS pane 9 11,085 11-19-2018, 02:46 AM
Last Post: pane
