canNOT boot after a normal apt upgrade
2nd know-how
tested work on a fresh burnt sdcard with 4.4.77
rock64@rock64:~$ sudo apt-cache showpkg linux-image
Package: linux-image
Versions:
Reverse Depends:
  firmware-crystalhd,linux-image
Dependencies:
Provides:
Reverse Provides:
linux-image-4.4.77-rockchip-ayufan-136 0.5.15 (= )
linux-image-4.4.77-rockchip-ayufan-118 0.5.10 (= )
linux-image-4.4.77-rockchip-ayufan-104 0.5.9 (= )
linux-image-4.4.77-rockchip-ayufan-102 0.5.8 (= )
linux-image-4.4.71-rockchip-ayufan-77 0.4.12 (= )
linux-image-4.4.70-rockchip-ayufan-85 0.4.17 (= )
linux-image-4.4.70-rockchip-ayufan-83 0.4.16 (= )
linux-image-4.4.70-rockchip-ayufan-66 0.4.3 (= )
linux-image-4.4.70-rockchip-ayufan-62 0.3.7 (= )
linux-image-4.4.70-rockchip-ayufan-57 0.3.4 (= )
linux-image-4.4.70-rockchip-ayufan-55 0.3.3 (= )
linux-image-4.4.70-rockchip-ayufan-54 0.3.2 (= )
linux-image-4.4.70-ayufan-29 0.2.1 (= )
linux-image-4.4.70-ayufan-28 0.2.0 (= )
linux-image-4.4.126-rockchip-ayufan-227 0.6.41 (= )
linux-image-4.4.126-rockchip-ayufan-226 0.6.40 (= )
rock64@rock64:~$ sudo apt-mark hold linux-image-4.4.126-rockchip-ayufan-227 linux-image-4.4.126-rock
chip-ayufan-226
linux-image-4.4.126-rockchip-ayufan-227 set on hold.
linux-image-4.4.126-rockchip-ayufan-226 set on hold.
Run "apt upgrade" and you'll see that 4.4.126 is gone.
However, some people said this method induce instability due to rapid changes on all packages. So, you are warned.
RE: canNOT boot after a normal apt upgrade - by cooker - 05-23-2018, 08:47 AM
  Rock64 won't boot dstallmo 0 377 12-27-2023, 10:34 AM
Last Post: dstallmo
  arch rock64 does not boot nemnob 0 630 07-09-2023, 03:28 AM
Last Post: nemnob
  Disabling last mount time check on boot acwest 0 662 03-03-2023, 09:24 PM
Last Post: acwest
  Swap/Upgrade Storage Device? r00t3d 0 717 08-17-2022, 06:11 AM
Last Post: r00t3d
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 7,909 06-30-2022, 06:28 PM
Last Post: rookie_267
  my rock64 can't boot rookie_267 0 1,079 06-27-2022, 06:52 PM
  Setting a MAC on Rock64 U-Boot kiriakos 2 3,633 03-23-2021, 04:51 AM
Last Post: kiriakos
  Boot from USB 3.0 with hub Turbo 0 2,143 12-20-2020, 02:24 PM
Last Post: Turbo
  Unable to boot armbian fchazal 2 3,920 05-19-2020, 06:43 PM
Last Post: Rocklobster
  Rock64s will not boot any OS camosoul 2 3,493 05-19-2020, 06:38 PM
