External hard drive problem
My PinePhone would not detect either a USB hard disk drive or SD card USB adapter when plugged into my dock so I was going through the suggestions in this thread. Although I've always hot plugged the dock into the PinePhone first and then connected the USB device afterwards (keyboard and mouse) and they were detected and immediately usable, this did not work with USB drives.
I found that the USB hard disk and USB SD card adapter both worked perfectly if I reboot the PinePhone after connecting the powered dock to it. After the reboot, I plug-in the USB drive. I'm running Mobian (https://images.mobian-project.org/pineph...113.img.gz) and I last did a apt get dist-upgrade about a week ago.
I post here just in case someone stumbles upon this thread and finds the above information helpful.
Also
uname -a
Linux mobian 5.9-sunxi64 #1 SMP PREEMPT Thu Nov 26 09:29:57 UTC 2020 aarch64 GNU/Linux
External hard drive problem - by k8Va - 03-20-2018, 06:53 PM
RE: External hard drive problem - by k8Va - 03-21-2018, 04:04 AM
RE: External hard drive problem - by Luke - 03-21-2018, 05:10 AM
RE: External hard drive problem - by k8Va - 03-21-2018, 11:38 AM
RE: External hard drive problem - by pfeerick - 03-21-2018, 08:43 PM
RE: External hard drive problem - by k8Va - 03-22-2018, 04:44 AM
RE: External hard drive problem - by k8Va - 03-27-2018, 03:39 PM
RE: External hard drive problem - by k8Va - 03-30-2018, 03:50 AM
RE: External hard drive problem - by rontant - 04-18-2018, 08:37 PM
RE: External hard drive problem - by frewind - 03-31-2018, 06:24 AM
RE: External hard drive problem - by xalius - 03-31-2018, 07:19 AM
RE: External hard drive problem - by k8Va - 04-04-2018, 06:56 AM
RE: External hard drive problem - by k8Va - 04-15-2018, 10:57 AM
RE: External hard drive problem - by k8Va - 04-19-2018, 06:36 AM
RE: External hard drive problem - by calinb - 12-08-2020, 03:37 PM
RE: External hard drive problem - by evaaa - 02-22-2021, 03:21 AM
RE: External hard drive problem - by calinb - 03-09-2021, 02:31 PM
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,666 10-12-2023, 05:14 PM
Last Post: tpaul
  Looking for guidance on setting up with external RTC Ditchmagnet 0 891 05-13-2022, 05:22 PM
Last Post: Ditchmagnet
Sad Rock64 crash randomly during usb 3 copy with RAID1 drive phalae 24 35,539 09-14-2020, 10:48 AM
Last Post: BrownLuther007
  Arch Linux Arm - external RTC problem max 1 3,012 08-17-2020, 10:35 AM
Last Post: max
  Read-only problem mikedhoore 5 6,929 07-14-2020, 11:41 AM
Last Post: zein
Question bluetooth rock64 problem deta 3 5,113 05-06-2020, 11:29 PM
Last Post: deta
  Fedora 31 crosscompilation fdt problem mimics debian 888789 kf5zmi 2 4,210 01-20-2020, 12:25 PM
Last Post: kf5zmi
  USB 3.0 hard drive write speed increase tip on Ubuntu 18.04 Wizardknight 3 6,944 05-26-2019, 10:28 PM
Last Post: Wizardknight
  ROCK64 Kernel compilation problem cao 0 2,492 01-21-2019, 01:21 AM
Last Post: cao
  USB drive powered off after reboot huberttrz 1 3,079 12-20-2018, 05:39 PM
Last Post: huberttrz
