Looking for guidance on setting up with external RTC
I'm currently using a Raxda Rock Pi 4, running Ubuntu Server 20.04.  I'm using it with grabserial to automatically create logs from a serial port I need to record.
I need to setup a bunch more locations doing this, so I was looking at the ROCK64_v2.0 on amazon since its just $30 for a whole kit.
I will be needing RTC functionality though since the locations I will have to put these wont have network access and I don't want to have to go set the time manually in the event of a power outage.
I have been trying to do some research on adding RTC to the ROCK64 and found that it appears possible.
According to this-
https://forum.pine64.org/showthread.php?...4#pid44024
It looks like they are using Ubuntu 18.04 there which will hopefully still be compatible with the usb-to-serial cables I'll use.
I think the RTC module he is using is this one on amazon-
https://www.amazon.com/AT24C32-Replace-A...r=8-5&th=1
But I also saw this thread -
https://forum.armbian.com/topic/8856-sol...k64-board/
Saying that this part was compatible with Armbian-
https://www.amazon.com/Adafruit-3296-DS1...119&sr=8-3
Additionally, it appears that this particular module is more accurate, which is the SN model-
https://www.amazon.com/Adafruit-3296-DS1...C83&sr=8-3
SO! Does what I want to do sound feasible? It also sounds like I could run Ubuntu 20.04 according to this post-
https://forum.pine64.org/showthread.php?...3#pid65313
I'm not sure I'm up to the task of getting the RTC module to work, I haven't every compiled a kernel etc, so this would really be a learning experience, but I'm worried I might get stuck too.
Any suggestions or insights would be appreciated!
  Setting a MAC on Rock64 U-Boot kiriakos 2 6,826 03-23-2021, 04:51 AM
Last Post: kiriakos
  External hard drive problem k8Va 17 36,652 03-09-2021, 02:31 PM
Last Post: calinb
  Arch Linux Arm - external RTC problem max 1 5,383 08-17-2020, 10:35 AM
Last Post: max
  Partitioning encrypted CCC Carbon Copy Cloner AND setting up Time Machine on HDD vidin 0 3,457 05-10-2020, 01:08 PM
Last Post: vidin
  monitor setting & keyboard issues gpine1 2 5,682 05-27-2018, 03:51 PM
Last Post: Luke
