External hard drive problem
Same result.
https://github.com/ayufan-rock64/linux-b...ses/latest  -->
jessie-openmediavault-rock64-0.5.15-136-armhf.img
Is there a problem with the chipset?  ASMedia ASM1053
root@rock64:~# dmesg | grep usb
[    0.588101] usbcore: registered new interface driver usbfs
[    0.588706] usbcore: registered new interface driver hub
[    0.589315] usbcore: registered new device driver usb
[    1.107739] phy phy-ff450000.syscon:usb2-phy@100.0: Looking up phy-supply from device tree
[    1.107760] phy phy-ff450000.syscon:usb2-phy@100.0: Looking up phy-supply property in node /syscon@ff450000/usb2-phy@100/host-port failed
[    1.108395] phy phy-ff450000.syscon:usb2-phy@100.1: Looking up phy-supply from device tree
[    1.108415] phy phy-ff450000.syscon:usb2-phy@100.1: Looking up phy-supply property in node /syscon@ff450000/usb2-phy@100/otg-port failed
[    1.108832] rockchip-usb2phy ff450000.syscon:usb2-phy@100: GPIO lookup for consumer otg-vbus
[    1.108848] rockchip-usb2phy ff450000.syscon:usb2-phy@100: using device tree for GPIO lookup
[    1.108889] of_get_named_gpiod_flags: parsed 'otg-vbus-gpios' property of node '/syscon@ff450000/usb2-phy@100[0]' - status (0)
[    1.109627] rockchip-u3phy ff470000.usb3-phy: GPIO lookup for consumer vbus-drv
[    1.109643] rockchip-u3phy ff470000.usb3-phy: using device tree for GPIO lookup
[    1.109675] of_get_named_gpiod_flags: parsed 'vbus-drv-gpios' property of node '/usb3-phy@ff470000[0]' - status (0)
[    1.110073] phy phy-ff470000.usb3-phy.2: Looking up phy-supply from device tree
[    1.110091] phy phy-ff470000.usb3-phy.2: Looking up phy-supply property in node /usb3-phy@ff470000/utmi@ff470000 failed
[    1.110616] phy phy-ff470000.usb3-phy.3: Looking up phy-supply from device tree
[    1.110635] phy phy-ff470000.usb3-phy.3: Looking up phy-supply property in node /usb3-phy@ff470000/pipe@ff478000 failed
[    1.112207] rockchip-u3phy ff470000.usb3-phy: Rockchip u3phy initialized successfully
[    1.618779] usbcore: registered new interface driver cdc_ether
[    1.619676] usbcore: registered new interface driver rndis_host
[    1.622431] phy phy-ff470000.usb3-phy.2: u3phy u2 power on
[    1.623213] phy phy-ff470000.usb3-phy.3: u3phy u3 power on
[    1.624895] dwc2 ff580000.usb: Looking up vusb_d-supply from device tree
[    1.624915] dwc2 ff580000.usb: Looking up vusb_d-supply property in node /usb@ff580000 failed
[    1.624933] ff580000.usb supply vusb_d not found, using dummy regulator
[    1.625948] dwc2 ff580000.usb: Looking up vusb_a-supply from device tree
[    1.625966] dwc2 ff580000.usb: Looking up vusb_a-supply property in node /usb@ff580000 failed
[    1.625981] ff580000.usb supply vusb_a not found, using dummy regulator
[    1.782396] dwc2 ff580000.usb: DWC OTG Controller
[    1.783052] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1
[    1.794720] dwc2 ff580000.usb: irq 40, io mem 0x00000000
[    1.806352] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.817899] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.829376] usb usb1: Product: DWC OTG Controller
[    1.840537] usb usb1: Manufacturer: Linux 4.4.77-rockchip-ayufan-136 dwc2_hsotg
[    1.852021] usb usb1: SerialNumber: ff580000.usb
[    1.924423] ehci-platform ff5c0000.usb: EHCI Host Controller
[    1.935841] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 2
[    1.947351] ehci-platform ff5c0000.usb: irq 41, io mem 0xff5c0000
[    1.964182] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00
[    1.975431] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    1.986415] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.997293] usb usb2: Product: EHCI Host Controller
[    2.007844] usb usb2: Manufacturer: Linux 4.4.77-rockchip-ayufan-136 ehci_hcd
[    2.018626] usb usb2: SerialNumber: ff5c0000.usb
[    2.072398] ohci-platform ff5d0000.usb: Generic Platform OHCI controller
[    2.082934] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 3
[    2.093459] ohci-platform ff5d0000.usb: irq 42, io mem 0xff5d0000
[    2.158419] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    2.168795] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.179236] usb usb3: Product: Generic Platform OHCI controller
[    2.189540] usb usb3: Manufacturer: Linux 4.4.77-rockchip-ayufan-136 ohci_hcd
[    2.199964] usb usb3: SerialNumber: ff5d0000.usb
[    2.275864] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    2.286667] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.297596] usb usb4: Product: xHCI Host Controller
[    2.308371] usb usb4: Manufacturer: Linux 4.4.77-rockchip-ayufan-136 xhci-hcd
[    2.319431] usb usb4: SerialNumber: xhci-hcd.8.auto
[    2.376856] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.388508] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003
[    2.400005] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.411566] usb usb5: Product: xHCI Host Controller
[    2.422872] usb usb5: Manufacturer: Linux 4.4.77-rockchip-ayufan-136 xhci-hcd
[    2.434506] usb usb5: SerialNumber: xhci-hcd.8.auto
[    2.472223] usbcore: registered new interface driver usbtouchscreen
[    2.719678] usbcore: registered new interface driver uvcvideo
[    2.841823] usbcore: registered new interface driver bfusb
[    2.853276] usbcore: registered new interface driver btusb
[    3.068897] of_get_named_gpiod_flags: parsed 'gpios' property of node '/switches/usb-switch[0]' - status (0)
[    3.084684] usbcore: registered new interface driver usbhid
[    3.092108] usbhid: USB HID core driver
[    3.099617] usbcore: registered new interface driver snd-usb-audio
[   13.319225] usb 5-1: device not accepting address 2, error -62
[   24.167216] usb 5-1: device not accepting address 3, error -62
[   35.015184] usb 5-1: device not accepting address 4, error -62
[   45.863209] usb 5-1: device not accepting address 5, error -62
[   45.901328] usb usb5-port1: unable to enumerate USB device
External hard drive problem - by k8Va - 03-20-2018, 06:53 PM
RE: External hard drive problem - by k8Va - 03-21-2018, 04:04 AM
RE: External hard drive problem - by Luke - 03-21-2018, 05:10 AM
RE: External hard drive problem - by k8Va - 03-21-2018, 11:38 AM
RE: External hard drive problem - by pfeerick - 03-21-2018, 08:43 PM
RE: External hard drive problem - by k8Va - 03-22-2018, 04:44 AM
RE: External hard drive problem - by k8Va - 03-27-2018, 03:39 PM
RE: External hard drive problem - by k8Va - 03-30-2018, 03:50 AM
RE: External hard drive problem - by rontant - 04-18-2018, 08:37 PM
RE: External hard drive problem - by frewind - 03-31-2018, 06:24 AM
RE: External hard drive problem - by xalius - 03-31-2018, 07:19 AM
RE: External hard drive problem - by k8Va - 04-04-2018, 06:56 AM
RE: External hard drive problem - by k8Va - 04-15-2018, 10:57 AM
RE: External hard drive problem - by k8Va - 04-19-2018, 06:36 AM
RE: External hard drive problem - by calinb - 12-08-2020, 03:37 PM
RE: External hard drive problem - by evaaa - 02-22-2021, 03:21 AM
RE: External hard drive problem - by calinb - 03-09-2021, 02:31 PM
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,488 10-12-2023, 05:14 PM
Last Post: tpaul
  Looking for guidance on setting up with external RTC Ditchmagnet 0 879 05-13-2022, 05:22 PM
Last Post: Ditchmagnet
Sad Rock64 crash randomly during usb 3 copy with RAID1 drive phalae 24 35,356 09-14-2020, 10:48 AM
Last Post: BrownLuther007
  Arch Linux Arm - external RTC problem max 1 2,997 08-17-2020, 10:35 AM
Last Post: max
  Read-only problem mikedhoore 5 6,901 07-14-2020, 11:41 AM
Last Post: zein
Question bluetooth rock64 problem deta 3 5,078 05-06-2020, 11:29 PM
Last Post: deta
  Fedora 31 crosscompilation fdt problem mimics debian 888789 kf5zmi 2 4,184 01-20-2020, 12:25 PM
Last Post: kf5zmi
  USB 3.0 hard drive write speed increase tip on Ubuntu 18.04 Wizardknight 3 6,911 05-26-2019, 10:28 PM
Last Post: Wizardknight
  ROCK64 Kernel compilation problem cao 0 2,484 01-21-2019, 01:21 AM
Last Post: cao
  USB drive powered off after reboot huberttrz 1 3,066 12-20-2018, 05:39 PM
Last Post: huberttrz
