Dual boot options for ROCK64?
(11-23-2017, 01:10 PM)freebsd Wrote: My guess is you would have to re-compile the kernels to pick the different slice on the flash AND a layer to boot up enough to give you a screen/keyboard to say 'what is the blob you want to load'.   Now perhaps someone would write such code for an IoT field upgrade model - 'Boot from this old version/boot the new version' and then that could get re-purposed for what you are looking for or someone wanting:
1) coreboot   https://www.coreboot.org/ARM running on the platform
2) NetBSD's model of doing a  device tree
https://www.cnx-software.com/2017/07/11/...h3-boards/
The short version is:  ARM is not the same as the bios model that brought you dual booting.
that noobs companion or the wd hd  rpi multi boot  code could maybe be modified to set up pine64 devices for multi-boot option.
berryboot source is on github so you could check that out to determine if hack is possible
Dual boot options for ROCK64? - by Mrfixit2001 - 11-14-2017, 12:57 PM
RE: Dual boot options for ROCK64? - by Tony32 - 11-22-2017, 05:46 AM
RE: Dual boot options for ROCK64? - by freebsd - 11-23-2017, 01:10 PM
RE: Dual boot options for ROCK64? - by dkryder - 11-24-2017, 04:52 AM
RE: Dual boot options for ROCK64? - by Tony32 - 01-15-2018, 12:31 PM
RE: Dual boot options for ROCK64? - by dudemo - 01-15-2018, 01:33 PM
RE: Dual boot options for ROCK64? - by maal - 01-15-2018, 01:51 PM
RE: Dual boot options for ROCK64? - by Luke - 01-15-2018, 01:51 PM
RE: Dual boot options for ROCK64? - by Luke - 01-15-2018, 03:23 PM
RE: Dual boot options for ROCK64? - by maal - 01-15-2018, 03:45 PM
RE: Dual boot options for ROCK64? - by Luke - 01-16-2018, 04:11 AM
RE: Dual boot options for ROCK64? - by maal - 01-16-2018, 08:55 AM
RE: Dual boot options for ROCK64? - by Luke - 01-16-2018, 10:06 AM
RE: Dual boot options for ROCK64? - by maal - 01-16-2018, 11:47 AM
RE: Dual boot options for ROCK64? - by Luke - 01-16-2018, 02:04 PM
RE: Dual boot options for ROCK64? - by Tony32 - 01-16-2018, 01:12 AM
RE: Dual boot options for ROCK64? - by ayufan - 01-16-2018, 02:26 PM
RE: Dual boot options for ROCK64? - by easyfab - 01-20-2018, 10:54 AM
RE: Dual boot options for ROCK64? - by a1w.ca - 01-21-2018, 10:47 PM
RE: Dual boot options for ROCK64? - by easyfab - 01-22-2018, 01:53 AM
RE: Dual boot options for ROCK64? - by a1w.ca - 01-22-2018, 02:00 AM
RE: Dual boot options for ROCK64? - by Luke - 01-22-2018, 04:42 AM
RE: Dual boot options for ROCK64? - by a1w.ca - 01-22-2018, 04:55 AM
RE: Dual boot options for ROCK64? - by Luke - 01-22-2018, 06:11 AM
RE: Dual boot options for ROCK64? - by a1w.ca - 01-22-2018, 08:10 AM
RE: Dual boot options for ROCK64? - by Luke - 01-22-2018, 09:17 AM
RE: Dual boot options for ROCK64? - by Danielsan - 04-20-2018, 01:47 PM
RE: Dual boot options for ROCK64? - by S3phi40T - 05-01-2018, 03:58 PM
RE: Dual boot options for ROCK64? - by pfeerick - 05-01-2018, 05:26 PM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 188 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,418 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 370 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 677 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 658 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,735 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 193,494 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 627 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 677 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  Disabling last mount time check on boot acwest 0 659 03-03-2023, 09:24 PM
Last Post: acwest
