Help with a MicroSD card problem on Rock 64
Thanks Luke ....
Forgot all about GParted .. brain fart.
deleted all the partitions on the microsd card in gparted, then, using disk management on windows, created a new volume .. and all is well.
I also went ahead and resized the partition, on the sd card in the rock64, to use all the empty space, while I was in gparted.
You are rught about the rock 64 images using a lot more partitions, then the PI ... looks like 7 on the rock 64.
Again, thanks for helping the noob.
Jake
RE: Help with a MicroSD card problem on Rock 64 - by Jakr - 08-10-2017, 06:49 AM
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,724 10-12-2023, 05:14 PM
Last Post: tpaul
  Buildroot 2021.08 not booting from SD card jimmy 1 2,065 11-08-2021, 02:25 AM
Last Post: hunderteins
  External hard drive problem k8Va 17 22,777 03-09-2021, 02:31 PM
Last Post: calinb
  Arch Linux Arm - external RTC problem max 1 3,018 08-17-2020, 10:35 AM
Last Post: max
  Read-only problem mikedhoore 5 6,959 07-14-2020, 11:41 AM
Last Post: zein
Question bluetooth rock64 problem deta 3 5,128 05-06-2020, 11:29 PM
Last Post: deta
  Fedora 31 crosscompilation fdt problem mimics debian 888789 kf5zmi 2 4,222 01-20-2020, 12:25 PM
Last Post: kf5zmi
  Rock 64 dashboard a639157781 0 1,886 01-07-2020, 10:14 AM
Last Post: a639157781
  Nextcloudpi SD card fills up. default_user8 13 16,957 12-04-2019, 01:30 PM
Last Post: Rocklobster
  ROCK64 Kernel compilation problem cao 0 2,497 01-21-2019, 01:21 AM
Last Post: cao
