Found newer firmware for broadcom wifi (brcmfmac43456-sdio)
(04-10-2022, 04:10 PM)jpalus Wrote: Note that there are firmware files at https://github.com/RPi-Distro/firmware-n...80211/brcm which identify as:
May 14 2020 17:26:08 version 7.84.17.1 (r871554) FWID 01-3d9e1d87
Version number is higher, revision is higher, date is earlier.
You are right to notice. The next day I spent more time searching for firmware. The confusing part, for me, is the following. See the next two version dumps. (Also in README on github.)
43455c5-roml/43455_sdio-pno-aoe-pktfilter-sr-pktctx-lpc-pwropt-txbf-wl11u-txpwr-wepso-linkstat-pwrstats-ndoe-tdls-mfp-ve-extsae-43455_ftrs-noclminc-ob
    Version: 7.45.96 (r745790)
    CRC: 301bcfe7
    Date: Mon 2020-11-16 16:27:54 CST
    Ucode Ver: 1043.20724
    FWID: 01-99758c86
and
43455c5-roml/43455_sdio-pno-aoe-pktfilter-pktctx-lpc-pwropt-43455_ftrs-mfp-noclminc-clm_min
    Version: 7.84.17.1 (r871554)
    CRC: 72494685
    Date: Thu 2020-05-14 17:41:11 KST
    Ucode Ver: 1043.20424
    FWID: 01-3d9e1d87
The revision is indeed larger for the earlier binary. I found this one as a patch proposal for merging in linux-firmware.git. However, the "Ucode Ver" (microcode-version, I would think) is significantly lower. So does this mean that the firmware is newer but the cpu microcode is lower? Also, given the top string, the firmware is compiled with certain features disabled? (I'm guessing. I'm not an expert.) Can you clarify these difference and/or recommend?
RE: Found newer firmware for broadcom wifi (brcmfmac43456-sdio) - by cobratbq - 04-12-2022, 02:36 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 907 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,087 07-15-2023, 02:58 PM
Last Post: u974615
  5GHz wifi not working snorwood 11 5,613 01-16-2023, 03:41 PM
Last Post: ehcorn
  Pinebook Pro wifi not working Queliffrel 1 1,319 11-30-2022, 06:30 AM
Last Post: myself600
  WiFi stopped on Pinebook Pro after update tkudog 3 2,626 11-24-2022, 04:32 PM
Last Post: tkudog
  Archlinux - missing firmware for wifi adapter RudderDuck 9 4,690 11-07-2022, 04:56 PM
Last Post: wgahnagl
  newer ""emmc-installer" images (manjaro xfce) magistral 1 1,111 10-10-2022, 06:22 AM
Last Post: maxjrh
  Help with Kali Linux wifi not working but works with Manjaro PineSupporter 2 2,388 08-25-2022, 02:15 PM
Last Post: Niko
  How to pack the firmware whit Rockchip loader bin files Brandwarden 3 2,116 04-29-2022, 12:18 PM
  Pinebook Pro wifi not working seyo-iv 2 3,804 10-26-2021, 02:27 AM
Last Post: wangyukunshan
