How to pack the firmware whit Rockchip loader bin files
I  get Manjaro-ARM-kde-plasma-pbpro-22.04.img.xz for pbpro, boot from TPL ,
If boot from rockchip loader bin,how to pack the firmware ?
TPL ??? do you mean uSD (micro SD) ?
are you asking how to write to SD ?
as root/sudo
zcat image,xz |dd of=device bs=1M
lsblk to find device name, do NOT write to partition
(04-28-2022, 03:13 AM)wdt Wrote: TPL ??? do you mean uSD (micro SD) ?
as root/sudo
no,I  mean I want to use Rockchip closed source loader bin as bootloader ,instead of open source loader .
Here is the boot flow ,Boot Flow 1 is typical Rockchip boot flow with Rockchip miniloader;  I do not know How to repack the  whole firmware with Rockchip loader bin files .
OK, I see what you mean now
This is ONLY to make usb useable ONLY to write a new image to emmc
It is NOT for booting
AFAIK, ,,, ALL media must be removed or disabled (and later re-enabled)
There is a program, rkdevelop IIRR that talks to boot rom, connects to usb driver
I have never done this
I think this is more for soldered emmc, better to get a usb adapter for emmc
Information Found newer firmware for broadcom wifi (brcmfmac43456-sdio) cobratbq 4 13,494 07-04-2025, 07:46 AM
Last Post: remph
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 18,986 06-26-2025, 09:20 PM
Last Post: reukiodo
  Void Linux: missing firmware from pinebookpro-firmware? remph 0 3,447 12-15-2024, 01:58 PM
Last Post: remph
  Archlinux - missing firmware for wifi adapter RudderDuck 9 16,220 11-07-2022, 04:56 PM
Last Post: wgahnagl
  Syncing files magistral 1 3,320 10-10-2022, 08:45 AM
Last Post: mikehenson
  Network settings, where to find the config files? hvdkooij 1 5,712 11-20-2020, 02:47 PM
Last Post: xyzzy
  PBP not starting up sometimes / [Firmware Bug]: Kernel image misaligned at boot pato3 8 17,539 10-17-2020, 09:52 AM
  Rescue boot loader? ocschwar 0 3,050 07-28-2020, 03:47 PM
Last Post: ocschwar
  Are there plans for the Pinebook Pro to support LVFS (Linux Vendor Firmware Service)? CuriousTommy 8 15,788 01-13-2020, 02:18 PM
Last Post: yangmusa
  Unable to read files on samba shares (but browsing OK) regivanx 0 2,974 01-05-2020, 08:34 AM
Last Post: regivanx
