Help with Kali Linux wifi not working but works with Manjaro
I usually use PBP with Manjaro and everything works great.  I recently flashed Kali on SD card but for some reason it's not connecting to wifi.  I'm still very new to Linux.  I tried searching online for the answer but can't seem to find it.
I ran airmon-ng command and this is what I got:
phy0      wlan0     brcmfmac        unable to detect for sdio 0x02d0:0xa9bf
Does anyone know what's wrong and how I can connect my wifi?
(05-27-2022, 10:24 PM)PineSupporter Wrote: Hello,
I had the same problem so I copied the same Kali file to the same SSD and then the network worked.
Here's the cmd I used:
xzcat kali-linux-2022.2-pinebook-pro-arm64.img.xz | sudo dd of=/dev/mmcblk1 bs=4M status=progress
If this doesn't work you can try to start networking manually with the following cmds:
# /etc/init.d/networking start
# /usr/sbin/NetworkManager
# nmcli device wifi list     /* if you get a  list then your networking is up
                                                 and you can connect to your wifi router using
                                                  the network icon on the upper right of your screen*/
# nmcli device wifi connect "$SSID" password "$PASSWORD"   /* if you don't see you router with list cmd, try this
        $SSID is your router name. the double
        quotes are necessary */
Anyway, by now you have probably solved your problem since this post was a month old.
I had a similar issue (I am not sure it is the same issue but who knows, it could help some people).
In my case, as I understand it (I may be wrong), the issue seemed to be caused by a different wireless card in the new pinebook-pro of 2022 compared to the previous one (I don't know about your version of the pinebook since you posted in May).
In my case, I could see the origin of the issue by typing in a terminal:
sudo dmesg | grep brcm
I saw some lines that contained words like "firmware:" and "failed to load". At some point (as I understand it), the driver for the Broadcom wireless card will ask udev for a firmware, in order to flash it in the Broadcom chip. It fails because the requested firmware is not present.
By the way the "dmesg" command seems really useful for beeing aware of failures that can happen when the kernel is booting. And it is not specific to Debian, so the command should be available on any linux distribution I guess.
The issue has been reported here and a fix was created.
I am not sure if the fix is already included in the kali release image from here or not yet.
Since I had already installed kali, I prefered fixing it without reinstalling it. Here is what I did.
I downloaded the missing files from gitlab:
https://gitlab.com/kalilinux/build-scrip...5-sdio.bin
https://gitlab.com/kalilinux/build-scrip...o.clm_blob
https://gitlab.com/kalilinux/build-scrip...ok-pro.txt
And I copied them into the filesystem of my kali installation inside the folder: "/lib/firmware/brcm"
Then, after a shutdown and a restart, I could connect to wifi networks.
I hope it will help some of you.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,581 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  Armbian fix, current version now works Sb2024 0 2,914 08-08-2025, 08:49 AM
Last Post: Sb2024
  Can’t login to Linux fnosai 0 3,315 07-27-2025, 12:30 AM
Last Post: fnosai
Information Found newer firmware for broadcom wifi (brcmfmac43456-sdio) cobratbq 4 13,271 07-04-2025, 07:46 AM
Last Post: remph
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 18,720 06-26-2025, 09:20 PM
Last Post: reukiodo
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,230 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,350 02-19-2025, 12:49 PM
Last Post: zkajdan
  Void Linux: missing firmware from pinebookpro-firmware? remph 0 3,360 12-15-2024, 01:58 PM
Last Post: remph
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 6,879 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Slackware Linux working on PBP vxzero 0 4,026 06-05-2024, 04:30 PM
Last Post: vxzero
