Pinebook Pro wifi not working
Tried the killswitch but it doesn't help. Few boots away I had WiFi while I was using my sd card. Now I get no wifi or every boot, no deference if sd card or ssd.
WLAN dongles and bluetooth also not working.
Also /etc/network/interfaces is not existing. And the NetworkManager.conf is empty. And I seem to miss the network manager service... Just freshly installed kde, before that I had xfce, sadly same problem
Problem was I had a missmatch with my boot partition which was still on the mmc even tho I booted ssd
(02-01-2021, 03:54 AM)seyo-iv Wrote: Tried the killswitch but it doesn't help. Few boots away I had WiFi while I was using my sd card. Now I get no wifi or every boot, no deference if sd card or ssd.
Me too
  Boot Order in Pinebook Pro food 12 13,772 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 3,578 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 12,961 08-09-2025, 06:53 AM
Last Post: Sb2024
Information Found newer firmware for broadcom wifi (brcmfmac43456-sdio) cobratbq 4 11,573 07-04-2025, 07:46 AM
Last Post: remph
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 15,871 06-26-2025, 09:20 PM
Last Post: reukiodo
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 4,860 03-15-2025, 01:47 AM
Last Post: frank_philip
  Pinebook pro won't boot after bootloader installation jwensouls 4 6,834 08-21-2024, 04:17 AM
  Slackware Linux working on PBP vxzero 0 3,288 06-05-2024, 04:30 PM
Last Post: vxzero
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 3,807 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 10,407 03-31-2024, 10:11 AM
Last Post: u974615
