Getting Waydroid to work on the Pinephone Pro
(04-02-2022, 10:24 AM)cbz Wrote: Hello
I try to install waydroid on mobian (on SD) with tow-boot on SPI.
After insert psi=1 in /etc/default/u-boot, i launch sudo u-boot-update, then i reboot PPP.
But psi=1 doesn't appear with the command cat /proc/cmdline
Any suggestions ?
Hmm, I did not have this issue. It showed up first time for me after the reboot. Make sure the file is saved and cat the config file before you run sudo u-boot-update to make sure it is in the u-boot config. I suppose it is possible the phone isn't saving your changes for whatever reason. If you didn't use sudo to write the file that could be the culprit. Just be careful updating the config too many times, let me know how it goes.
RE: Getting Waydroid to work on the Pinephone Pro - by Dragonborn - 04-14-2022, 04:07 PM
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 16 2,042 04-28-2024, 01:52 AM
Last Post: diederik
  Tow-Boot, a new U-Boot option for Pinephone Pro and other devices Ulfnic 60 45,501 02-13-2024, 02:54 PM
Last Post: fxc
  A Btrfs Image for Arch SXMO on the Pinephone Pro mburns 2 861 11-23-2023, 08:44 AM
Last Post: mburns
  Rhino Linux does not seem ready for the PinePhone Pro. mburns 2 987 11-23-2023, 08:39 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 724 11-07-2023, 09:44 AM
Last Post: mburns
  Seeking Contributors: Apache NuttX Real-Time Operating System for PinePhone Pro lupyuen 2 1,746 09-14-2023, 07:23 PM
Last Post: lupyuen
  What to do if your PinePhone Pro does not boot fxc 19 19,586 09-10-2023, 03:19 AM
Last Post: fxc
  Waydroid No Network Hell pinemegood 4 2,181 07-15-2023, 08:16 PM
Last Post: SpoofyKid
  My Waydroid Manager call for testers / assistance MadameMalady 0 684 07-15-2023, 02:16 PM
Last Post: MadameMalady
  Pinephone(pro) modem bug / shortcomings MadameMalady 2 2,474 06-19-2023, 03:40 PM
