Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching
Megapixels is not loading on PinePhone Pro with Mobian.
I had installed the prerequistes (according to thread in this forum) for Megapixels:
$ sudo apt install dcraw
$ sudo apt install imagemagick
What is required to have the Megapixels camera app to work in Mobian?
Thank you
mobian@pinephonepro:~$ megapixels
/usr/share/megapixels/config/pine64,pinephone-pro.ini not found
Could not find any config file
mobian@pinephonepro:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description:    Debian GNU/Linux 12 (bookworm)
Release:        12
Codename:       bookworm
I had to save megapixels, my custom files, and its dependency libtiff.so.5 and libtiff.so.5.8.0 from an older image of mobian. A yet older version of megapixels is required if you want auto exposure to work. The mobian camera app works for me.
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 14 1,875 Yesterday, 05:40 AM
Last Post: diederik
  Tow-Boot, a new U-Boot option for Pinephone Pro and other devices Ulfnic 60 45,217 02-13-2024, 02:54 PM
Last Post: fxc
  Disable the GDM service in Mobian. mburns 0 468 11-25-2023, 10:19 PM
Last Post: mburns
  A Btrfs Image for Arch SXMO on the Pinephone Pro mburns 2 843 11-23-2023, 08:44 AM
Last Post: mburns
  Rhino Linux does not seem ready for the PinePhone Pro. mburns 2 977 11-23-2023, 08:39 AM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 893 11-18-2023, 08:21 AM
Last Post: crocspot
  Fix the Mobian Weather App mburns 0 502 11-07-2023, 10:01 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 604 10-14-2023, 11:57 AM
Last Post: mburns
  Seeking Contributors: Apache NuttX Real-Time Operating System for PinePhone Pro lupyuen 2 1,729 09-14-2023, 07:23 PM
Last Post: lupyuen
  What to do if your PinePhone Pro does not boot fxc 19 19,480 09-10-2023, 03:19 AM
Last Post: fxc
