A Btrfs Image for Arch SXMO on the Pinephone Pro
In order to recover from the unmaintained Manjaro Plasma distribution for the Pinephone Pro, I attempted to convert the Manjaro distribution to use the DanctNIX Arch repositories. But, although I found a cookbook list of steps to convert from Manjaro, the cookbook did not specify correctly how to renew the Arch keys. And I am not sure if the DanctNIX repository is included.
So I did not persist, and then gave Rhino Linux a tryout.
The keyboard symbols became a priority for me, so I tried to fix the issue on the Mobian Phosh partition. I could only manage to fix the missing symbols on the Linux console screens.
Next, I installed a btrfs image of DanctNIX SXMO for the Pinephone Pro. The main partition needed extension using gparted on a USB connection, and the btrfs format had to be explicitly extended. The complete re-installation of the Arch keys was needed. The required Zathura package was not preinstalled, and Megapixels and Surf do not work. The btrfs snapshots are not preconfigured. A bluetooth mouse will not install, but it is kind of an alien idea to SXMO.
But the keyboard symbols work!
(10-08-2023, 12:40 PM)mburns Wrote: In order to recover from the unmaintained Manjaro Plasma distribution for the Pinephone Pro, I attempted to convert the Manjaro distribution to use the DanctNIX Arch repositories. But, although I found a cookbook list of steps to convert from Manjaro, the cookbook did not specify correctly how to renew the Arch keys. And I am not sure if the DanctNIX repository is included.
Arch keys are generated by
sudo pacman-key --init
sudo pacman-key --populate archlinux
Then you should sync the packages and update the keyring
sudo pacman -Sy
sudo pacman -S archlinux-keyring
Then do a whole system update
sudo pacman -Syu
If you need to add the DanctNIX repository. Add it to the /etc/pacman.conf
Source: https://github.com/dreemurrs-embedded/Pi...nf.aarch64
$sudo nano /etc/pacman/conf
#Add these line to the bottom of the file
[danctnix]
Server = https://p64.arikawa-hi.me/aarch64/danctnix/
Then you should sync the packages again
The mouse problem was apparently my fault. I did not setup the mouse correctly for pairing.
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 14 1,881 Yesterday, 05:40 AM
Last Post: diederik
  Image Latest Phones Ship with vorell 6 620 02-29-2024, 01:00 AM
  Tow-Boot, a new U-Boot option for Pinephone Pro and other devices Ulfnic 60 45,220 02-13-2024, 02:54 PM
Last Post: fxc
  Rhino Linux does not seem ready for the PinePhone Pro. mburns 2 977 11-23-2023, 08:39 AM
Last Post: mburns
  Arch SXMO Stopped Booting After A Megi Linux Update. mburns 0 466 11-07-2023, 09:52 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 714 11-07-2023, 09:44 AM
Last Post: mburns
  Seeking Contributors: Apache NuttX Real-Time Operating System for PinePhone Pro lupyuen 2 1,730 09-14-2023, 07:23 PM
Last Post: lupyuen
  What to do if your PinePhone Pro does not boot fxc 19 19,483 09-10-2023, 03:19 AM
Last Post: fxc
  Pinephone(pro) modem bug / shortcomings MadameMalady 2 2,462 06-19-2023, 03:40 PM
Last Post: MadameMalady
  Cannot update new PinePhone Pro bent 6 3,515 05-15-2023, 02:43 PM
Last Post: alaraajavamma
