Mobian PIN changed after update!
(02-04-2021, 12:35 PM)C0ffeeFreak Wrote:
(02-04-2021, 10:44 AM)Mwo87 Wrote:
(02-03-2021, 10:53 AM)signal9 Wrote: I'm running into a similar problem, but the pin is getting changed while I'm doing an apt update, not using the Software application. I did try to update via ssh, but found the connection dropped and I couldn't get back in. Updates from KingsCross were faster, it seemed, but once the screen locked, well, you know the rest.
There does seem to be a GitLab issue with Mobian:
https://gitlab.com/mobian1/issues/-/issues/174
I'll be trying some of these suggestions once I have time, will report back if anything of use comes of it.
I was using apt-get because the Software application was not working, so it was the same problem.
I don't think it really changes the pin. It's just the update locks you out if it finishes in the terminal and the screen is off. It needs a restart to finish the install, holding the power button in, powering off then powering back on will usually finish the install and your pin will work again. At least that has worked for me.
I mentioned above that rebooting led to an unusable phone. Obviously there are some issues that still need ironing out and keeping Mobian on the SD card instead of installing it seems a reasonable precaution for now.
Mobian PIN changed after update! - by Mwo87 - 01-29-2021, 08:59 PM
RE: Mobian PIN changed after update! - by Mwo87 - 01-29-2021, 10:28 PM
RE: Mobian PIN changed after update! - by Mwo87 - 01-30-2021, 10:50 AM
RE: Mobian PIN changed after update! - by signal9 - 02-03-2021, 10:53 AM
RE: Mobian PIN changed after update! - by Mwo87 - 02-04-2021, 10:44 AM
RE: Mobian PIN changed after update! - by Mwo87 - 02-04-2021, 04:28 PM
RE: Mobian PIN changed after update! - by dawg161 - 02-05-2021, 07:59 PM
RE: Mobian PIN changed after update! - by Mwo87 - 02-07-2021, 12:29 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 7,000 12-04-2023, 02:14 AM
Last Post: Peter Gamma
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 4,258 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
  No longer waking up from sleep after recent update gamerminstrel 2 1,318 01-23-2023, 08:33 AM
Last Post: gamerminstrel
  No sound after Mobian upgrade arbocenc 1 773 11-28-2022, 11:02 AM
Last Post: arbocenc
  no sdcard boot and manjaro update failed Gwen 3 1,417 11-27-2022, 07:56 AM
Last Post: fxc
Exclamation No wIfI after Mobian update crakabeats 3 2,134 11-03-2022, 04:16 AM
Last Post: wifinoworkie
  pinephone-support package not upgradable on Mobian fhireman 4 2,385 09-24-2022, 08:01 AM
Last Post: dante404
  update kills keyboard ludgate 1 1,191 05-18-2022, 12:43 AM
Last Post: programmin
  PinePhone running Mobian - Malware extraction? names_fold 1 1,644 01-24-2022, 12:00 PM
  Mobian updates for phosh steves 2 2,108 01-17-2022, 02:18 AM
Last Post: bcnaz
