Mobian updates for phosh
Howdy,
This is likely a very stupid question... However, I've been keeping my pinephone up to date running mobian via `apt-get update; apt-get full-upgrade`, and have noticed that it's still on phosh 0.11.0-1mobian1, when the latest phosh is 0.14.1. Also looking at debian the latest stable is 0.08.0, and the latest unstable is 0.13.1.
Why is phosh stuck at such an old version or is there something wrong with my mobian updates?
https://blog.mobian-project.org/posts/20...e-release/
Upgrading from
bullseye
to
bookworm
won’t be automated and will require editing your
sources.list
files: simply replace
bullseye
with
bookworm
in both
/etc/apt/sources.list
and
/etc/apt/sources.list.d/mobian.list
Notes:
  • if you originally flashed your device with an image older than April 26th, 2021, will have to edit
    /etc/apt/sources.list.d/extrepo_mobian.sources
    , replacing
    Suites: mobian
    with
    Suites: bookworm
  • if you were using Mobian unstable so far, you will only need to edit
    : our current
    unstable
    repo will keep being the entry point for all new and updated packages we upload
Or just download and flash the latest weekly release ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  pinephone-support package not upgradable on Mobian fhireman 5 7,475 02-28-2026, 05:49 PM
Last Post: baptx
Exclamation No wIfI after Mobian update crakabeats 5 7,443 02-28-2026, 04:18 PM
Last Post: baptx
  60fps display updates possible without GPU? WhiteHexagon 2 1,594 12-31-2025, 12:46 PM
Last Post: WhiteHexagon
  What is wrong with the Mobian signature key? Mahgue 0 1,176 11-08-2025, 05:13 AM
Last Post: Mahgue
  Clamares password needed with new Mobian installation fauvetan 1 2,914 06-26-2025, 03:00 AM
Last Post: merom
  box86 Actually Works Well on Manjaro Phosh/xfce jakfish 9 10,351 06-30-2024, 12:26 AM
Last Post: Peter Gamma
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 14,095 12-04-2023, 02:14 AM
  Mobian PIN changed after update! Mwo87 21 32,999 12-02-2023, 11:53 PM
Last Post: Karrenbrady
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 8,267 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
  Phosh - Tweaks and Customizing mikehenson 0 5,507 01-07-2023, 01:35 PM
Last Post: mikehenson
