08-31-2020, 11:16 AM
you could do everything with hantro as it also has h264 support, however rkvdec supports h264 also and is favored.
you should be able to review the linux and ffmpeg scripts, files under /resources/, and kwiboo's repositories for linux-rockchip and ffmpeg. see how these are addressed by libreelec - kwiboo prepares patches for matching repositories, and the linuxtv-rkvdec linux-rockchip branch is additional WIP, but usually stable.
if possible, i would rebase your project on 5.8. i will be rebasing the hwaccel patches for 5.9 soon.
i added ADDPATCH and KERNELCONFIG variables to the linux script, so you may be able to use the script with your own patch and kernel for your project. this approach can actually work for any rockchip hardware with some effort, snd i will soon be expanding for rockpro64.
