Best Solution to run a TvHeadend on Rock64?
Didn't need hauppauge support myself. My driver hadn't been back ported in the kernel I was using so using the PPA from Brad Love's GitHub did the trick. Just letting the OP know what to look out for.
@tophneal
@Rocklobster
This could work for DVB-S2:
https://www.linuxtv.org/wiki/index.php/P...ick_(461e)
@Tetterl It absolutely could! I almost posted a link to the LinuxTV wiki page for supported devices, but it hasn't been kept up and all the devices listed on the page were relics by now. There are far more supported USB tuners than given.
The OP should find all the driver and firmware support he needs here. Brad Love is active and only too glad to help https://github.com/b-rad-NDi/Ubuntu-medi...el-builder
I try to install:
Ubuntu 18.04 Bionic minimal 64bit (arm64) Image [microSD / eMMC Boot] [0.8.3]
When I start the Rock64 there is no desktop.
Kind of Terminal.
I put in User/Password both rock64, but it stays in Terminal.
Is ther any command to go to desktop?
Is this a bug, what can I do?
Then I tried:
Ubuntu 18.04 Bionic LXDE Desktop Image [microSD / eMMC Boot] [0.8.3]
But this started with Debian! Funny.
What is my mistake?
Where do I find a working Version of Ubuntu minimal or Desktop??
Thanks again!
Update:
Image I found on:
https://wiki.pine64.org/index.php/ROCK64
was this:
bionic-minimal-rock64-0.8.3-1141-arm64
Possible too old, is the Wiki Version old?
Now I download from github:
bionic-minimal-rock64-0.9.14-1159-arm64
Hope this will work.
"minimal" means no desktop ...
You can try some images from https://dl.armbian.com/rock64/archive/
@martinayotte
Thank you.
Then minimal is too minimal for me.
I will take:
bionic-lxde-rock64-0.9.14-1159-armhf.img.xz
Do you want your Rock64 with TV Headend to run as a server only or are you wanting a front end to work on it too. If its purely a server minimal will do fine
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 185 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,414 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 367 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 670 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 652 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,693 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 192,772 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 626 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 676 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 34,262 12-07-2022, 08:22 PM
Last Post: luminosity7
