Best Solution to run a TvHeadend on Rock64?
Hello community
I want use my Rock64 as TvHeadend.
What is the best image to do this?
I dont have experience with this.
I tried Libreelec, I seen to run unstable and slow, compared to my Odroid C2.
Android Images, I found only Android TV Images on download site, running Kodi even more slow.
So I stopped using the Rock64 for Kodi.
But I wrote that TvHeadend works well on Rock64.
I want to use it for IPTV and possible DVB S.
What is the most stable and fast Image to install/use TvHeadend?
Debian Stretch, Ubuntu or Libreelec?
I want to use it with Timeshift and recording on USB 3.0 HDD.
By the way, does the hardware allow transcoding?
I own a 64GB eMMC on a Rock64 v2.0
Thanks a lot for your help!!!
Tetterl
I've had good luck with TvHeadend on several similar boards, running Debian or Ubuntu.
Do I need a Desktop Version of Debian or Ubuntu, or is a minimal Version enough?
Ubuntu appears to be the most stable. Have a look here for yourself and decide http://www.deb-multimedia.org/
(03-11-2020, 08:07 AM)Tetterl Wrote: Do I need a Desktop Version of Debian or Ubuntu, or is a minimal Version enough?
minimal will do just fine. All TvHeadend configuration is done through a local webpage, so you won't need it to have any desktop. The site will be accessible through any other computer on your network with a web browser.
What hardware do you propose to use for DVB-S
@Rocklobster
No idea, DVD-S only option yet.
Any suggestions?
@tophneal
Thanks, so I will take this image:
Ubuntu 18.04 Bionic minimal 64bit (arm64) Image [microSD / eMMC Boot] [0.8.3]
(03-11-2020, 12:18 PM)Tetterl Wrote: @Rocklobster
Any suggestions?
@tophneal
Most modern ones will likely work. I've had good experiences with Hauppauge and AVerMedia dongles with TVH.
Hauppage USB but research here on Ubuntu drivers. Can be a bit temperamental https://hauppauge.com/pages/support/support_linux.html
(03-11-2020, 01:32 PM)Rocklobster Wrote: Hauppage USB but research here on Ubuntu drivers. Can be a bit temperamental https://hauppauge.com/pages/support/support_linux.html
Huh, well don't let that scare you from giving one of their models a shot, OP! I have one of the most temperamental ones they make (only supposed to support Windows and NVidia Shield TV, and the drivers gave no problems on Ubuntu/Armbian. Their support is also very helpful, last time I reached out, the person who responded was the writer/maintainer of the Linux drivers.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 139 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,347 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 331 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 605 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 603 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,337 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,168 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 586 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 643 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,250 12-07-2022, 08:22 PM
Last Post: luminosity7
