Rock64 Rev3 doesn't boot and leds blinking fast
I just purchased a 4gb Rock64 Rev3 model and i'm struggling in getting any image to boot properly, i tried latest Armbian, mrfixit and ayufan's image. Whenever i plug my power supply (5v 4A) the white, red and ethernet led starts blinking very fast while the green blink slowly. If i plug in and out my power supply it will eventualy boot, but never from the first time. Maybe my board is defective? Anyone else has this issue?
(08-11-2019, 07:57 PM)dishins Wrote: Hello,
Sounds like a power issue, the green LED should be on solid when plugged in regardless if the board is booted or shutdown as it's hardwired to the power socket..
I'm not sure, my Rock64 1gb Rev1 board boots fine with the same power supply, also, if i plug and replug several times it will eventually boot. Is the Rev3 more power hungry. Actually the green led behaves more like a DIM than blink i should say.
Did You solve? I have the same problem.
Did You solve?  I have a  similar problem.  I use the Ubutu system ,and the board is not start normally,  and all LED is on,  includthe red one.
Did you try Armbian
no, I purchased another one ,which is work well .
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 153 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,373 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 619 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 613 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,424 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,749 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 593 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 652 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  Disabling last mount time check on boot acwest 0 628 03-03-2023, 09:24 PM
Last Post: acwest
