Broken eMMC boot
I have a PBP (2021 batch) and screwed up the original Manjaro KDE eMMC image with some combination of cups and display resolution mischief. I have been using Armbian successfully from a microSD card but want to fix my eMMC boot. The only image of Majaro that targets eMMC specifically is this one, but it's way out of date. I have since tried to update packages etc but am running into pretty difficult challenges getting things updated to a point where I could update the OS to a current version (namely I can't access the current mirror list). This is preventing me from using the manjaro-arm-installer package that would help update OS. Has anyone else run into this issue and solved it? Or is there another OS with a current eMMC version?
Thanks for any advice!
you don't need an emmc-installer img if you have a working Armbian on your SD. Simply boot into Armbian, download the more recent image from here: https://manjaro.org/downloads/arm/pinebo...de-plasma/ then mount your emmc and write the img to it using dd in Armbian's terminal
(04-27-2022, 08:35 AM)tophneal Wrote: you don't need an emmc-installer img if you have a working Armbian on your SD. Simply boot into Armbian, download the more recent image from here: https://manjaro.org/downloads/arm/pinebo...de-plasma/ then mount your emmc and write the img to it using dd in Armbian's terminal
all fair points, unfortunately I forgot to mention that with the old version of Manjaro KDE running on eMMC, any OS I put into my microSD is not recognized (power light stays red instead of transitioning to green).
the easiest solution will likely be to remove the bottom cover and use the switch to disable the emmc. then you can boot into the SD img, flip the switch to enable the emmc again, and rebind it so the SD install sees it (bind commands can be found in the wiki)
  Manjaro Sway Theme Broken Eighty8 1 290 03-08-2024, 08:41 AM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,157 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,233 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 414 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,249 11-23-2023, 07:37 AM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,983 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Emergency Mode Boot Hotkey? jiacovelli 20 4,449 06-02-2023, 01:32 PM
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,507 04-01-2023, 03:22 PM
Last Post: TRS-80
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 3,862 04-01-2023, 02:58 PM
Last Post: TRS-80
  Suspend/Resume Broken with Bootloader on SPI Flash xp19375 2 1,170 03-24-2023, 04:25 PM
Last Post: srs5694
