GAPPS (Waydroid) on the Pinephone Pro
So I got waydroid (sort of) working on my phone. I installed the GAPPS image, but Play Protect won't even let me install apps through the play store. Not a big deal if you use outside images, but I am assuming that the app I want specifically (Google Voice) is going to need GAPPS functioning. Any ideas?
Normally you'd need to register your Google Services Framework Android ID at https://www.google.com/android/uncertified/?pli=1 like you would for a typical custom rom that isn't certified. But as far as I can tell the waydroid image doesn't actually have an ID. At least in the Arch version its not shown in the menus and the adb commands don't run properly. If you figure out a way to extract the GSF ID I'd be interested to know.
(03-30-2022, 07:33 PM)brb78 Wrote: Normally you'd need to register your Google Services Framework Android ID at https://www.google.com/android/uncertified/?pli=1 like you would for a typical custom rom that isn't certified. But as far as I can tell the waydroid image doesn't actually have an ID. At least in the Arch version its not shown in the menus and the adb commands don't run properly. If you figure out a way to extract the GSF ID I'd be interested to know.
I'll see what I can figure out.
I have used Device ID or ( ANDROID_RUNTIME_ROOT=/apex/com.android.runtime sqlite3 /data/data/com.google.android.gsf/databases/gservices.db "select * from main where name = \"android_id\";" ) from sudo waydroid shell . Though upon registering it doesn't activate on the device. The GSF ID also resets on container reboot.
This has been my experience with this though.
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 14 1,866 Today, 05:40 AM
Last Post: diederik
  Tow-Boot, a new U-Boot option for Pinephone Pro and other devices Ulfnic 60 45,203 02-13-2024, 02:54 PM
Last Post: fxc
  A Btrfs Image for Arch SXMO on the Pinephone Pro mburns 2 842 11-23-2023, 08:44 AM
Last Post: mburns
  Rhino Linux does not seem ready for the PinePhone Pro. mburns 2 975 11-23-2023, 08:39 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 710 11-07-2023, 09:44 AM
Last Post: mburns
  Seeking Contributors: Apache NuttX Real-Time Operating System for PinePhone Pro lupyuen 2 1,728 09-14-2023, 07:23 PM
Last Post: lupyuen
  What to do if your PinePhone Pro does not boot fxc 19 19,467 09-10-2023, 03:19 AM
Last Post: fxc
  Waydroid No Network Hell pinemegood 4 2,144 07-15-2023, 08:16 PM
Last Post: SpoofyKid
  My Waydroid Manager call for testers / assistance MadameMalady 0 673 07-15-2023, 02:16 PM
Last Post: MadameMalady
  Pinephone(pro) modem bug / shortcomings MadameMalady 2 2,460 06-19-2023, 03:40 PM
