Mobile Data not working
Hello.
I got my pinephone a few weeks ago, played around with different operating systems and environments. But it was only yesterday, that I first tried to use it with a SIM card, because I want to start using it as a daily driver. I'm using the Manjaro 3gb CE.
Calls and SMS work good on postmarketOS, but mobile Internet doesn't. So I'm wondering, if this is just a software problem (I tried various operating systems including the preinstalled and updated Manjaro, postmarketOS, ubports and by using the multiboot image I also tried PureOS, KDE Neon and some other) or if my network provider just isn't supported (using O2 Germany). If the second is the case, I'm willing to change the provider, but I must be sure, if this is really the problem. APN was selected automatically in postmarketOS and seems to be correct according to research I did (pinternet.interkom.de). The status bar shows '4G' and mobile data should work in this area.
There is also a second problem, that the signal gets lost from time to time to an unknown state and gets reconnected after a few minutes, maybe this is related to the non-functional mobile data. I read some older threads describing this problem as well.
Finally, I would like to use the change to thank Pine64 and the community for making all this possible. Thank you!
Greetings
Well, it is working now (on pmOS) after manually entering the APN, although I'm not sure why exactly it is working. Testing it since an hour without issues.
Things are getting strange ...
It used to work for for a couple of hours (I don't know why) - had constantly mobile internet without any issues - but after I did a reboot it doesn't work anymore ...
first of all, follow the following:
https://wiki.pine64.org/wiki/PinePhone_APN_Settings
For me the mobile internet works without any problems since I have created new APN (profile) in my pmOS with Phosh as per documentation. Did test it after reboot as well and I see no problems.
Is the APN profile still available after you have rebooted?
  4G VoLTE calls confirmed working with carrier x dcinoz 15 12,255 03-09-2024, 11:38 PM
Last Post: dcinoz
  can I retrieve accidentally deleted voice mail with T mobile ? HLing 4 1,011 12-13-2023, 01:24 AM
Last Post: oldschool
  how to backup user data? Uturn 1 721 08-30-2023, 05:23 AM
  New Zealand network providers mobile data Linux2thabone 3 3,358 08-05-2023, 06:17 AM
Last Post: SchizoPinePhone225
  US Mobile, via T-Mobile, won't support Pinephone Pro - SOLVED, SIMPLY jovval 10 3,530 07-07-2023, 12:06 PM
Last Post: jovval
  Problems updating KDE Plasma Mobile OS IMSAI8080 6 3,517 06-30-2023, 11:39 PM
Last Post: ionmich
  Current Situation With Setup and Carrier Activation With Tracfone Verizon T-Mobile pinephoneuser22 0 744 05-26-2023, 08:40 PM
Last Post: pinephoneuser22
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 4,337 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
  Cannot call at several mobile phones Gon 3 1,418 05-04-2023, 05:18 AM
Last Post: Gon
  MMS sending stopped working amindfv 2 1,307 01-16-2023, 09:44 PM
Last Post: treebeard
