how to backup user data?
if I have installed a distro and I want to switch to semthing else, is there a good way to transfer my user data to the new system?
You can use SFTP to transfer the data from a running system, or you can backup the whole contents of the eMMC using dd (in the opposite direction you would use to flash a new image, but otherwise following the same instructions, i.e., booting the Phone with a JumpDrive microSD card and connecting it to the computer over USB) and then you can mount the contents of the image on the computer to get at the data (though it is a bit tricky because the image contains multiple partitions, unless you dd just the / partition (e.g. /dev/sdx1) to an image file rather than the whole device (e.g. /dev/sdx)).
As usual on GNU/Linux, you will mainly want to backup the contents of your home directory. Possibly also some stuff under /etc and/or /var.
  New Zealand network providers mobile data Linux2thabone 3 3,300 08-05-2023, 06:17 AM
Last Post: SchizoPinePhone225
  Can't get through "User Configuration" on new PinePhone a-l 24 18,825 06-01-2023, 10:08 AM
Last Post: feketej
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 4,251 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
  cell data and MMS on AT+T prepaid ossands 2 1,460 10-13-2022, 07:28 AM
Last Post: ossands
  Misunderstanding the user base orbital 9 4,053 08-18-2022, 03:21 PM
Last Post: alaraajavamma
Question Mobile data suddenly gone epiii2 1 1,348 05-23-2022, 04:57 PM
Last Post: epiii2
  likely bug, volte does not work when operator side data blockage is activated zetabeta 1 1,277 05-21-2022, 03:03 PM
Last Post: zetabeta
Star Pinephone user experience - Possibly compromised by commercial & state-based hackers? danimations 15 7,597 05-07-2022, 06:54 PM
Last Post: danimations
  Pinephone 64 Issues of a new user US Notheast as of April 2022 scrwbigtek 9 5,562 05-03-2022, 04:18 PM
Last Post: scrwbigtek
  No data access on ATT prepaid but my plan has data dc2daylight 6 4,694 04-03-2022, 02:14 PM
Last Post: dc2daylight
