[Release] Fedora 32 Workstation, KDE, Xfce, and Cinnamon Images
Hello Everyone,
I just wanted to update everyone that I finally have a stable build up that supports EMMC completely.
These images include several new fixes and enhancements. Some of those are listed below:
New Features/Fixes
  • EMMC Support
  • Boot partition is separate
  • SELINUX support in the kernel (disabled out of the box)
  • Updated wireless drivers
  • Custom kernel packaging more closely resembles the official Fedora kernel packages
  • Several new desktop environments
Downloads
Fedora 32 Cinnamon Desktop
Fedora 32 KDE Desktop
Fedora 32 Xfce Desktop
Note: You will have to login to other DE using root/fedora and configure your user account as they do not provide a initial setup wizard like GNOME.
Please let me know if you run into any issues, I've been running it as my primary OS without any.
Cheers,
Mike
These Fedora 32 images are great. I'm having one issue with charging the Pinebook pro while using the Fedora 32 Cinnamon image above. I've tried a USB-C 3 amp charger and the barrel charger that came with the PBP. both seem to just hold the charge not increase it. In one case when opening the dnfdragora software manager the battery level actually dropped while on the charger.
I installed CPUFreqUtil to try and lower the CPU frequency thinking it was stuck on performance but it was using shedutil which should balance out the CPU. That setting seems to work well on Manjaro.
Any thoughts?
I have an NVME drive installed. I wonder if that's causing the power draw.
Hello wideawake,
thank you very much for these Images. I've installed the KDE one on a SD-card. At the first look everything is working fine.
Is there any work to get Fedora Kernel working? As I know, kernel 5.7 should support this CPU.
Again, thank you.
Andreas
Now I'm in the process to copy the SD-Card to EMMC.
[url=https://forum.pine64.org/member.php?action=profile&uid=11940][/url]
Everything works (KDE) except dnfdragora (the only not-gray button is quit, all versions, ncurses,gtk,qt)
Sleep does need the change to sleep.conf (etc/systemd), seems as good as manjaro (SuspendState=mem)
Cube also works
Only about 1/2 of my wifi dongles work, lack of firmware
(I have quite a collection, because hub needed reset checked them all)
Running Fedora 32 with Gnome.
The installer was perfect didn't take long to install and worked out of the box.
I haven't played much with the sleep but overnight it used around 30% battery. Not sure if screen was just turning off so more investigating.
Either way i'm very happy with the base I've got so far.
Will keep updating this thread as i go.
Sleep should be <10%/day, more like 7%
/etc/systemd/sleep.conf,,, change to SuspendState=mem
I enter/leave with pwr button, don't know how to set that in gnome
pwr button and lid magnet are the only live things when in suspend,
everything else is dead
OH, and BTW, will not usb boot, usb stick light flashes, and on and on, 20 min,
it should find the LABEL............
Thank you for this release!
It works like a charm installed on an SD card!
However, I was unsuccessful so far in copying it over to the eMMC.
It starts booting and then complains that it's unable to load some rockchip driver I suppose.
(I didn't had my phone at hand those multiple times I tried, so no photos at this time)
Any others that were successful with booting Fedora from eMMC?
I now have the unofficial Debian installed which works fine enough and boots very quickly compared to default Manjaro.
(09-11-2020, 10:48 AM)Tharadash Wrote: Thank you for this release!
Hello Tharadash,
I'm booting my Fedora from eMMC. Just "dd" the SD-Card to eMMC. And resize afterwards. Thats all.
I have to install "linux-firmware" to eliminate the errors about USB-C-Dockingstation.
Greetings
Andreas
Andreas
Hello Tharadash,
Greetings
Andreas
Andreas
Hi Andreas
I finally got Fedora running.
I had to screw open the PBP in order to flash it directly to eMMC.
Now, the only real issues I have are:
Headphone/speaker switching does not work --> sound both from speakers and headphones
dnf is throwing some "errors" that the kernel is out-of-date.
@wideawake, any updates on how you're getting along with the kernel?
Is there any hope that we're running a mainline kernel soontm?
Kind regards
Tharadash
Hello Tharadash,
Greetings
Andreas
Andreas
Hi Andreas
Kind regards
Tharadash
Hello Tharadash,
maybe next week, when I have more time, I will try speakers and headphones. I had no trouble with dnf regarding kernel.
Also I can try to install a fedora kernel. As i know, kernel greater 5.6 supports the Pinebook Pro. And actual we have 5.8.
Greetings
Andreas
  Fedora 37 installation gswatkins 16 6,187 03-16-2024, 03:09 PM
Last Post: michel_luc
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,526 12-08-2023, 11:25 PM
  Fedora 36 -> 37 upgrade kills system tydeman 0 464 10-28-2023, 09:53 AM
Last Post: tydeman
  Upgrade Fedora from 37 to 38? acruhl 2 925 07-12-2023, 09:31 PM
Last Post: acruhl
  Armbian 22.02 release announcement TRS-80 22 13,989 04-01-2023, 03:19 PM
Last Post: TRS-80
  newer ""emmc-installer" images (manjaro xfce) magistral 1 1,121 10-10-2022, 06:22 AM
Last Post: maxjrh
  Fedora Workstation (36) on Pinebook Pro u974615 13 7,390 09-02-2022, 11:24 AM
Last Post: u974615
  No audio on Pinebook Pro with Fedora? foobar 1 1,423 08-22-2022, 12:12 PM
Last Post: snorwood
  OpenSUSE with XFCE/ GNOME3 now available Luke 35 54,644 01-10-2022, 01:06 PM
Last Post: werwolf
  Fedora 33 to 34 upgrade issues tydeman 2 2,500 12-02-2021, 02:43 AM
Last Post: linuxfreund
