no speakers on debian
iv'e recently installed debian on my PBP. in contrary to the Majarno, the speakers and the headphones output did not work at all. iv'e searched the subject online but couldn't find a solution. how do i turn the speakers on? and the headphones output as well?  Angel
you have to unmute and raise lvl on alsamixer.
@imryk
Are you referring to mrfixit Debian in the wiki ?
If so, there was a fix posted way back, maybe November or so of last year.
I had to use that myself, but I do not remember the specifics, but it did fix the sound for many of us back then.
if there was a fix, i'll be glad to get it. anyhow, iv'e opened the alsamixer, and i raised all of the levels. still no sound tho
If I get a chance I will dig back through the old forum posts and find that "FIX"
If I remember correctly there were quite a few of us that had to do that repair,        but oddly not everyone.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
PROBLEM SOLVED
i installed kali instead of debian, and easily configured the speakers to work. also, many softwares just didn't work on debian (at all), and everything works just fine (everything which is arm64 compatible) on the kali. so the pinebook pro quickly became a very usefull machine
these sound issues are solved on any mainline linux OS with the proper configurations. i use them in pbp-tools and my forked danielt debian installer.
  Official Debian support moonwalkers 63 52,996 05-16-2024, 11:00 PM
Last Post: rempfer
  Debian on Pinebook Pro u974615 7 1,456 03-31-2024, 10:11 AM
Last Post: u974615
  install debian on pbp jsch 7 4,214 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,725 09-07-2023, 09:38 PM
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,239 07-15-2023, 02:58 PM
Last Post: u974615
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,322 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,407 12-09-2022, 05:04 AM
Last Post: ndp
  How can I install Debian? ImmyChan 1 2,118 10-19-2022, 03:09 AM
Last Post: alpopa
  when i close my laptop lid the screen doesn't turn on? (debian bullseye based) computerc 3 1,982 09-23-2022, 08:37 PM
Last Post: computerc
  Debian emmc installer db579 6 3,112 08-23-2022, 06:13 AM
Last Post: db579
