Restore default Debian system
#41
Also, before I broke the bootloader on the eMMC, the only way to get it to boot from SD card was to boot into the default Debian distro, then do `sudo reboot`. Actually powering it off and on again always booted into eMMC, no matter what I did.
Is that supposed to be default behaviour?
#42
(11-07-2019, 08:29 AM)fire219 Wrote: It's pretty simple! Download the latest build of the default Debian image, flash to an SD card, boot from the SD card, and let it flash to the eMMC.
I get the installer; try to run it, and get the message:Exec format error. The same for for Etcher.
With: pine64-installer-2.0.0-beta.3-linux-x64.AppImage.
Loaded Ubuntu onto the micro in my other computer; worked on that computer, but when I used it on my Pine it did not recognize it as bootable, and simple mounted the two directories on the micro.
#43
(02-03-2020, 07:39 PM)PineFan Wrote: If you get an opportunity could please provide an Amazon link to the USB to emmc adapter you ordered or even better the product's ASIN #?  I have not seen one for  less than $20 USD.  Thanks in advance!
Search your local version of www.digikey.com for "emmc reader" they also have an adapter to microSD. I recommend you pick up another eMMC module and, maybe, a UART to USB adapter at the same time.
#44
(02-03-2020, 01:14 PM)uby89 Wrote: Eh eh thanks. I did a lot of reading, and my understanding is that with emmc disabled, and a sd card inserted with an OS with uboot on it should boot.
But it doesn't, which is slightly worry me.
I also tried re-flashing uboot on my current debian OEM on the emmc, checking the ribbon cable connecting the sd card. No luck.
I might have to wait for the usb adapter, but it does bother me that I should be able to boot from sd... and I could sort my emmc from there.
I've encountered an issue with similar symptoms. Have you tried another kind of image on the SD card with the bad eMMC still on? I had my bad eMMC (Manjaro) boot to login on a Debian SD but the Manjaro SD wouldn't except with a good Debian eMMC.
  Official Debian support moonwalkers 63 53,930 05-16-2024, 11:00 PM
Last Post: rempfer
  Debian on Pinebook Pro u974615 7 1,637 03-31-2024, 10:11 AM
Last Post: u974615
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 477 03-01-2024, 06:46 PM
Last Post: Puckla
  Nethunter default password failed lamlarryyyy 0 453 11-23-2023, 02:48 AM
Last Post: lamlarryyyy
  install debian on pbp jsch 7 4,303 11-22-2023, 04:22 PM
Last Post: TRS-80
  Fedora 36 -> 37 upgrade kills system tydeman 0 562 10-28-2023, 09:53 AM
Last Post: tydeman
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,914 09-07-2023, 09:38 PM
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,328 07-15-2023, 02:58 PM
Last Post: u974615
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,346 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,464 12-09-2022, 05:04 AM
Last Post: ndp
