Update stock OS to Debian Buster?
Hey,
just received my Pinebook Pro yesterday and started to update and install some software on it. Looks like the stock Debian OS is still Debian 9 (and there seems to be some limitations with newer packages such as Flatpak) is there an official way to upgrade the stock OS from Debian 9 to Debian 10 Buster? Or would it better to reinstall from scratch with the unofficial Debian installer?
Someone experience with flatpak usage on ARM devices?
Thanks a lot,
Andreas
you would change your apt sources to jump to a newer release while keeping the same kernel. ...i wouldnt do that, tho. the default os is hacked together. who knows what will break.
the unofficial debian installer uses the manjaro kernel so there are many differences.
i use debian sid arm64 using the manjaro kernel with great results.
You could consider this thread https://forum.pine64.org/showthread.php?tid=8487 which skips over Buster and goes to Bullseye. There are assorted problems with the files it relies on this early, but going this route then doing the update/upgrade bit should move you toward something more stable looking forward. And you won't have to replace it so soon. There is the option of installing Buster this way now.
FYI, I was able to do this via the usual strategy of replacing "stretch" with "sid" in /etc/apt/sources.list, and get an apparently stable system. as a warning, this did require a great deal if finagling with dependencies (eg, packages trying to overwrite other packages which needed to be purged, etc). it also somehow wiped out my mate installation, which i was fine with since i prefer xfce anyway?
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,026 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 17,354 06-26-2025, 09:20 PM
Last Post: reukiodo
  Official Debian support moonwalkers 64 115,022 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  Debian on Pinebook Pro u974615 7 11,496 03-31-2024, 10:11 AM
Last Post: u974615
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 3,861 03-01-2024, 06:46 PM
Last Post: Puckla
  install debian on pbp jsch 7 11,459 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 21,790 09-07-2023, 09:38 PM
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 4,568 08-21-2023, 09:10 PM
Last Post: vanessadonald
  Manjaro update: nerd-font-terminus dependency issue Vinay 3 4,342 05-10-2023, 04:51 AM
Last Post: Vinay
  Manjaro update broke hardware video acceleration with mpv myself600 2 4,690 01-25-2023, 09:12 AM
Last Post: myself600
