phone working on UT-#246
big improvements ,from UT-#244 and 246
 texts work
phone calls  working (decent sound )
#246 (Mar 9, 2020 7:49:36 AM)
  1. Use a lighter wallpaper for pine — Marius Gripsgard / gitlab
  2. Make sure to set correct modem audio config — Marius Gripsgard / gitlab
#244 (Mar 7, 2020 10:48:27 PM)
  1. [pinetab] set 'tablet' machine type — nekit1000 / gitlab
  2. Add debug mode to selected images — Marius Gripsgard / gitlab
  3. Add audio, modem and voicecall fixes — Marius Gripsgard / gitlab
What is needing to be done to make the phone calls work; should it work automatically? do the bits for the modem need to be different than +QDAI: 1,0,0,1,0,1,1,1?
I do not appear to have a connection instead always getting call failed... Previously I could dial and connect but had no audio throughput.
At the moment I do have sms, mms, and data working without too much fuss.
I am using a AT&T sim card from a Google phone, I have inconsistently been able to make out-going calls, usually on the third try.
( first two try's it says 'call failed' )
Sometimes the audio is crystal clear, sometimes not very clear, sometimes no audio at all, but it seems to stay connected until I disconnect it.
Calling in from another phone, it usually just pops up "call failed" no ring or anything else.
I was able to connect my laptop with the phones 'Hot Spot' for a few minutes, several times.
BUT, It gives an AT&T message that I "do not have Data Services" ... ? BUT I DO HAVE DATA SERVICE... !
The same card does work for Data service in the Google phone.
The wifi works Super, surfing and watching YouTube, the browser does need some work on screen 'Scaling' but otherwise works Great,
That is until I attempt to use the 'HotSpot', after using the hotspot, the wifi is Broke until I re-flash the SD card.
( Debian/Phosh has the same problem )
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  E-mail on the pine phone thorensjubilee 4 8,463 02-05-2023, 04:57 AM
Last Post: thorensjubilee
  How to answer a call on a sleeping phone Athansor 1 6,379 10-20-2021, 05:03 PM
Last Post: lacriz
  Screen-off = dead phone okgo 11 22,333 09-27-2021, 07:53 PM
Last Post: jtn0514
  Nextcloud Account setup not working kelbot 3 11,794 04-21-2021, 11:25 AM
Last Post: lsitongia
  Making phone calls PinePhoneCoder 7 18,158 03-23-2021, 06:33 AM
Last Post: israel
  UBPorts Not Working Pinoideae 7 17,104 03-13-2021, 01:51 PM
Last Post: KNERD
  If you're ready to tinker - here is how to get the more features working right now Luke 17 50,427 01-09-2021, 12:14 PM
Last Post: Csanderson0313
  Pinephone 3G Bluetooth Working Pretty Well With Latest Mobian Updates rmcg 0 4,381 09-27-2020, 10:22 PM
Last Post: rmcg
Question Camera(s) not working? UNi 9 23,043 09-06-2020, 10:45 AM
Last Post: Cree
  Is UT in PinePhone same thing than in another phone? natasha 23 43,795 08-24-2020, 10:23 AM
Last Post: Cree
