Running into problems while installing RStudio from sources
new user here. After I was able to compile R from the source codes and encouraging links in the internet (see http://ramseygurley.blogspot.com/2014/02...n-arm.html). However, when I try to invoke
sudo ./install-dependencies-debian
I am, first of all, quite puzzled that all R/libraries are again installed from scratch, second I get the following error:
Traceback (most recent call last):
  File "/opt/rstudio-tools/depot_tools/gn.py", line 75, in <module>
    sys.exit(main(sys.argv))
  File "/opt/rstudio-tools/depot_tools/gn.py", line 70, in main
    return subprocess.call([gn_path] + args[1:])
  File "/usr/lib/python2.7/subprocess.py", line 168, in call
    return Popen(*popenargs, **kwargs).wait()
  File "/usr/lib/python2.7/subprocess.py", line 390, in __init__
    errread, errwrite)
  File "/usr/lib/python2.7/subprocess.py", line 1024, in _execute_child
    raise child_exception
OSError: [Errno 8] Exec format error
I read at the rstudio-forums about a similar issue (https://community.rstudio.com/t/setting-...b/18982/44) but found there no answer.
Does somebody had any success with compiling Rstudio on a pinebook pro and/or know what to make of the above error?
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 9,921 12-13-2023, 07:22 PM
Last Post: trillobite
  Big bluetooth problems ColoBill 2 4,337 12-15-2022, 01:38 PM
Last Post: ColoBill
  DiY - Installing Void Linux ARM On The Pinebook Pro vincele 1 3,803 11-28-2022, 05:03 PM
  Is anyone successfully running guix system on PBP bluekeys 8 16,529 08-29-2022, 01:19 PM
Last Post: bluekeys
  Problems installing/ booting a different Linux on PinebookPro v-man 3 7,531 03-22-2022, 06:37 PM
Last Post: pentamassiv
  Installing debian on pinebook pro (deb installer/emmc) ljones 14 25,007 02-08-2022, 02:47 AM
Last Post: Humid Stylus
  Boot problems jessef 11 18,103 05-16-2021, 11:13 AM
Last Post: djhnsn
  Installing cinnamon on Manjaro PBP [SOLVED] quixote 1 5,620 05-09-2021, 01:39 PM
Last Post: quixote
  Running x86 software GloriousCoffee 19 38,937 02-15-2021, 11:43 AM
Last Post: jiyong
  installing OS from SD to eMMC methods for flashing SD PineHead7 3 11,648 12-22-2020, 06:52 PM
Last Post: jiyong
