Restoring the OS using the eMMC Adapter
The "simple" way I restored the OS using the eMMC adapter and was up and running.
I ran into issues getting the OS installed from the SD card Angry
Idea Since the SD card method failed, I used the eMMC adapter instead. If you don't have an adapter, here are a few links where you can purchase one.
I purchased mine from the Pine64 store which took a while to arrive.
Downloads Needed
  1. Download the OS on a separate computer. https://wiki.pine64.org/index.php/Pinebo...an_Desktop
  2. You'll need to flash the eMMC. I recommend using Balena Etcher https://www.balena.io/etcher/
Restoring the OS
  1. Turn off your PBP, open the back, and remove the eMMC flash memory from the motherboard. See here for where to find it and other specs: https://wiki.pine64.org/index.php/Pinebo...Reassembly
  2. Attach the eMMC to the eMMC adapter and place the adapter in an open USB slot within the separate computer.
  3. Open Etcher on the separate computer and follow the instructions on how to flash the eMMC you have plugged into the USB slot. It's the same process as flashing an SD card.
  4. Once Etcher is complete, reinstall the eMMC in the PBP and close it up.
  5. Power up!
  6. After your PBP boots up (you'll see the OS logo screen twice), log in using the rock/rock username/password combo.
  7. Make sure the PBP has internet access so you can run the updates.
  8. When the updates finish, follow the instructions on how to update the trackpad firmware. https://forum.pine64.org/showthread.php?tid=8407
  9. After the second reboot, during the trackpad upgrade, you should be good to go  Cool
Seems to have worked for me so far.
I had purchased a 128gb eMMC  that I flashed using the Pine Store eMMC to usb adapter.
First try with the eMMC using Etcher.
.  (  I also loaded a copy onto an SD card )
.  (I had to reseat the card and restart the Laptop I was using as it did not see  )
.    ( my SD card the first try, but it did work on the second try. )
> I still need to install the new 128gb eMMC into my PBP,  So I will update this Post when I get
.   the chance to proceed.
. Etcher does seem to be a good easy to use tool.
. I also used MrFixIt's OEM OS
Thank you for sharing
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(01-07-2020, 04:49 PM)bcnaz Wrote: Seems to have worked for me so far.
No problem. I used this method to upgrade my PBP to the 128 gig eMMC as well. It's been solid ever since.
(01-06-2020, 08:02 PM)xircledev Wrote:
I recommend you add https://www.digikey.ca/products/en/devel...ageSize=25
  How to rewrite uboot to emmc pineitup 5 15,486 12-27-2020, 10:35 AM
Last Post: nightranger73
  How to install Ubuntu to eMMC and to install KDE (Neon) Wizzard 66 162,040 12-22-2020, 03:05 PM
Last Post: Wizzard
  Using 2 OS images on eMMC for safe upgrades Arwen 0 3,940 06-13-2020, 01:13 PM
Last Post: Arwen
  How to boot Manjaro from NVME with uboot on eMMC as400 47 99,229 06-07-2020, 02:37 AM
Last Post: as400
Photo Using a v2.1 SSD adapter to fit a 2280 SSD (without trackpad interferance) danielt 9 36,837 02-02-2020, 03:23 AM
Last Post: Natrox
