An unofficial Debian Installer for Pinebook Pro
Debian 10 + Manjaro Kernel
My experience from running Debian 10 for a few days:
The kernel is rock stable. Debian 10 with xorg is rock stable. I don't run into the instability of Bullseye (as reported here and there on the forum).
Potential downside is graphics. I can live with it and patiently wait for Debian 11:
  • Firefox: youtube can play videos up to 720p in native resolution and full-screen as well. The cpu load is reasonable low.
  • Mplayer can play videos up to 720p in native resolution, only. The cpu load is reasonable low. Mplayer can't scale 720p video to full-screen. Other video players have one issue or another as well.
For a few days, I was running fbturbo, but it trashed my /var/log/Xorg.log file with 50MB/day of harmless messages. I did not see an improvement in video playback. Maybe there are some other subtile improvements elsewhere? Anyway, I'm back to the default xorg driver.
I've seen folks building mesa-git on Bullseye. In theory, it should be also possible on Debian 10. Last week, I tried building mesa-git but it had dependencies on wayland and so I stopped. Also, you don't have the convenience of apt-get automagically applying the latest bug and security fixes.
Debian 10 is good enough for me. You mileage may vary. Its biggest selling point is it simply works.
you can edit the mesa-git script to exclude wayland if you want (?). is that your only objection?
(01-29-2020, 12:40 PM)Der Geist der Maschine Wrote: Debian 10 + Manjaro Kernel
This sounds good and a great way to go.  Hope it continues to prove out.   Love Debian 10.   Thanks for the update and sharing.
< SNIP >
After futzing these few days on Bullseye, I'm just about ready to join you on Buster.
What changes did you make to @danielt installer to pull a Buster debbootstrap, or what arguments did you supply?
I will bootstrap a new install on my just working nVME. apt-clone or dpkg set-selections/get-selections ought to be enough to migrate my working desktop, and an rsync of my $HOME will save the dumb, manual recreation of every setup item!
— Jeremiah Cornelius
you can edit the installer for almost any debian channel. I did this to install unstable directly. from memory...
search for bullseye in the installer debootstrap and change the release.
change the repos in /etc/apt/sources.list
(01-29-2020, 04:51 PM)xmixahlx Wrote: you can edit the installer for almost any debian channel. I did this to install unstable directly. from memory...
Thanks! I got the bullsye/buster change in the install-debian script. But? I'd missed the sources.list!
Here we go again!
https://imgur.com/a/sDuEGAJ
< SNIP >
These were my changes on top of Daniel's debbootstrap http://students.engr.scu.edu/~sschaeck/s...ster.patch
Note, I also made the boot more verbose. You may not need all my changes. It is very important that you don't blindly replace bullseye with buster in etc/apt/sources.list. Use my sources.list from the patch.
I used the standard commandline arguments. Nothing special.
Please report back if you should find issues with Debian 10.
(01-29-2020, 04:59 PM)Der Geist der Maschine Wrote: These were my changes on top of Daniel's debbootstrap http://students.engr.scu.edu/~sschaeck/s...ster.patch
Perfect. And yes, I'm ready to share!
How are you applying the patch? I see it's not just for the install-debian script. I'll try patch -p0 < buster.patch on a copy of the git branch and see what goes...
Hey. That worked!
...very important for what reason?
(01-29-2020, 07:13 PM)xmixahlx Wrote: ...very important for what reason?
When replacing bullseye with buster, not all entries in source.list are valid, anymore
The details escape me, but when the installer was processing source.list it just ended. No error message. As I have never run the installer before, I thought the installation was complete, but it was not.
The take-away, you need a complete and correct source.list file.
By the way, the only problem on Debian 10 is mplayer messing up the mouse pointer. My work-around is this alias
alias mplayer='(sleep 2; xsetroot -cursor_name left_ptr) & /usr/bin/mplayer'
xsetroot regenerates the mouse pointer (after 2 seconds).
I don't think it should matter as Debian 10 is pretty mature, but my desktop environment is Mate and things simply work.
  Debian on Pinebook Pro u974615 7 1,320 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,834 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,243 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,341 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 90,000 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,345 11-23-2023, 07:37 AM
  install debian on pbp jsch 7 4,156 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,633 09-07-2023, 09:38 PM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,492 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,555 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
Users browsing this thread: 7 Guest(s)
